Hidden Benefit Of Watch Repairing!
In one word"..................... Patience!
Yesterday I decided to replace the rear shock absorbers on my car. This should have been an easy job 'cause is was only seven bolts per side and five of these held on the wheel. Thinks to myself total time for both sides about fifty minutes................wrong! The lower bolts that hold the shocks to the axel took one and a half hours per side to unscrew 3/4". If it hadn't been for "Plus Gas" a four foot lever and PATIENCE they would not have unscrewed.
Thank goodness for the Zen of horology!
Edited by Geo
Your are right there Geo,  without patience a person will not get far with watch repairing and even if someone has patience,  have they got the touch?  It`s one of the things I like about watches as a hobby, being able to go from wielding a 4ft. wrecking bar to adjusting a hairspring,  talk about extremes.
This is my biggest hurdle as I'm not a patient person by nature! Many a time I have to stop working on something and calm my nerves or I will get frustrated and either brake something or loose my mind! :roadrage:
I am an extremely impatient person (just ask my wife) but miraculously watch repairing is my therapy. I am at my most calm when at the bench.
Having two teenagers on the other hand......  :growl:
Changed the rear springs on my 30 year old rusted up Landrover Series 3 a couple of years back took 2 hours. Recently did my 10 year old Mitsubishi L200 took 2 days, swearing, plus gas, more swearing, heat, even more swearing, angle grinding, references to Roger Mellys Profanisaurus, drilling & swearing!
Ah, a man after my own heart. I too would have used heat, but there was too much rubber nearby.
I'm away to put my old Norton back together tomorrow, at least everything is clean and the majority of the fasteners are new!
Same here, Being in the motor mechanic bussiness for 23 years and constant fiddling with old cars you must have patience, Seen that SO many times. my rule is ...before you strip.... understand it FIRST, then diagnose THAN you get the hammer  ....   HAMMER: Originally employed as a weapon of war, the hammer now days is used as a kind of divining rod to locate expensive boat parts not far from the object we are trying to "adjust". Available in a variety of sizes, which is typically chosen based on the amount of time you have already wasted attempting to "solve a problem". Available with a head made of steel, plastic, brass or hard rubber. As a side note, only the steel head has a practical use, no logical use for the other materials has ever been discovered. Some models equipped with the fly away head option. AKA "Ford Wrench", "BFH", "Wound Inflicting Hammer"
:lolu: :lolu:
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
