How to make acrylic crystals?
Not sure what's behind your question, but if it's gone yellow, it will be polymethylmethacrylate, better known as PMMA or acrylic. More here about how it's made here: https://en.m.wikipedia.org/wiki/Poly(methyl_methacrylate)
There are many ways to achieve the shape - die moulding, die forming, machining, etc. At one time, I understand it was common to use a flat crystal and spring it into place with a domed press. I have a box full of flat round crystals, but don't have a press!
The yellowing is caused by cross-linking of the long polymer strands which make up the material, which in turn is caused by exposure to UV light. The cross linking will also make the material more brittle.
S
18 hours ago, StuartBaker104 said:
Thank You StuartBaker 104!
Since this watch meant to be cost efficient, the crystal over the dial seems to fit perfect in the back. So i have a sample.
Will try to make a plaster die mould with the original piece.
Made the mold for the crystals from plaster. Hope it will work.
Now i need 1mm thick PMMA or polycarbonate. You are right, i need PMMA :
https://www.fasttech.com/forums/vapers/t/1413346/pmma-acrylic-vs-pc-polycarbonate/1
I have access to a heating oven. 160 Celsius is needed to make the PMMA soft.
These high diameter crystals were fitted while heating up the bezel ring. The book says it is just dropped in, no press needed, just a heating plate.
Heatmolded some dvd-cover pieces which are 1mm thick polystyrene. 2016-05-06 08.21.30.jpeg
One of four seems acceptable.
At this stage I turned my attention to glass since railroad watches were usually equipped with glass crystal.
Heatglued a piece of 2mm glass on my special "lathe". The circe was cut with a tungsten carbide bit and the edge shaped with diamond powdered dremel disk and co**BLEEP** honing stone.
After fine shaping with 2000 grit sandpaper the glass was fitted on a special crystal fitting tool (heating the bezel over a candle and copper plate).
Perfect :)
And suddenly .... I couldt close the lid :( 2mm glass is to thick.
Ordered some laboratory hourglasses. They are 1.7-1.8mm thick.
Just finished the domed glass for the Roskopf from one of them. The final diameter is 40.05mm. First, 45-46 mm middle was cut.
Here is the finished crystal, the old plastic one, the front bezel and the tools i used. Desired diameter was reached with the diamond disc. 1000 Grit sandpaper, 3000 grit and finally 10000 grit diamond paste was used on the edge.
Perfect heat-fitting. No fancy cement or glue :)  However, i added some diluted UV glue on the edges after fitting to make sure it wont fall off. It will cure tomorrow on the sun :) Now i am waiting for the thin flat glass for the back bezel.
Edited by szbalogh
@Szbalogh I genuinely admire your ingenuity and your "can do" approach to your projects. You put me to shame for my reticence to tackle some of the more challenging aspects of watch repair just because I haven't got the "right" tools. I just love the solutions you put together to get the job done, and by the look of it the end results show that ecxellent results can be achieved without spending a small fortune on tools, just so long as you have a bit of inventiveness and a positive and determined approach.
I salute you :Bravo:
Thank You Marc! The hardest part was to determine if the diameter is perfect. If i grind it to small it is falling off. If its to big when i get it from the chuck the it is a pain to get it smaller evenly without turning. Luckily it is easy to get the screw nut off the turn and measure if it just over snapping in.
2 hours ago, ramrod said:
i believe that borel's has flat glass less than 2 mm.
Yes, i wanted thinner but couldt find. Even thin flat is hard to get. I was reading somewhere that they were between 1 and 2 mm, it is just unusual today :)
  • 3 months later...
Fianlly i colud acqure six pieces of 1mm thick 50mm round glass. Already broke one. Wanted to try shellack as a glue instead of hot glue for mounting on the chuck screw, but shellack has a much higher softening temperature. More intense heating was needed, i tried it evenly but while letting it cooling down the glass was suddenly broken.
Ah yes, that is needed  for the back cover.
Edited by szbalogh
3 minutes ago, parmenion31 said:
Great job , i am impressed , mostly by the "primitive" tools i see in the pictures producing an excellent outcome, maybe you should make us a video how you cut-polished that glass .Great effort
Ah yes, maybe. I will grind one in the near future :)
    • “Traditional” was probably a poor choice of words. What I was trying to say was that I perceived Waggy's proposal as more modern than the now generally accepted one. Water and sugar? Do you have a source on that or is it just a guess? Is the inside of the crown stainless? Water and metal don't sound like a very good combination otherwise.
    • Hello and welcome to the bottomless rabbit hole! 😉
    • Do you use an ultrasonic cleaner or a watch cleaning machine? I've been considering trying out the L&R liquids you mention in my "ancient" Elma watch cleaning machine. However, I worry that these liquids are too toxic and smell too much without adequate ventilation. Where I live it is normally too cold to work with this outdoors, but a few months a year it could work. At some point, I tried Elma's Suprol Pro and almost passed out from the fumes. It comes with a "narcotic effect" warning. How bad are the L&R fluids in this respect?
    • I've removed the movement and left it on a windowsill. I'm in north east England, so not very sunny today 😥 however I'll give it a few days and then try a new battery. The document you sent claims the movement is the same as the C700 with regards to parts and assembly. I've managed to find an exploded view of a C700 and some troubleshooting instructions. So if a new battery doesn't work in a few days I'll strip the watch and test the electronic circuit unit. No doubt it will require cleaning and oiling anyway. Thanks again for your help @watchweasol
    • Hello and welcome to the forum,     Enjoy
