Help Needed
Can anyone help? I puchased a beautiful Audemars Piguet RB3 Rep from InTime a couple of months ago, I have worn it only twice, but today when I came to it there was a problem.
The watch was "dead" when I came to put it on (obviously), so i woke it up with a few gentle shakes of the wrist and it sprung into life. I changed the date and the time, but noticed that the minute hand wasn't moving. As far as I can see all the subdials are working with the exception of the middle centre one (hours).
The top right button sticks in now when pressed - this starts the main second hand, but it can gently be pulled out with tweezers and you can hear a "click" when you do.
it has the A7750 movement.
This was a very expensive Rep and i'm gutted that it isn't working, but surely it can't be for the bin?? can someone shed some light, or offer advice on who to send it to to get it repaired?
I am in England and would be very grateful for a point in the right direction!!!
Thanks.
hello aerohot,
Welcome to the forum.
It doesn't sound like a major problem at all if it's running.  Sounds like one of the pushers may have locked something up. I haven't quite gotten to a chronograph movement yet, but many here have.
I would suggest you re-post, and ask for help by phrasing your request as having to do with an Asian 7750 clone: don't mention Audemar Piguet because it is not that.
Most watchmakers will not work on a clone for some reason, even though clone movements have been kitchen tested as being just as workable as Valjoux/ETA.... But some people just don't look kindly on them.
Regards,
JC
Welcome to the forum from me too aerohot. I'd say post some pictures? The problem with Replicas is sometimes the movements and/or parts as difficult to either source or not "economical" to repair. Just for the sake of the example, how much is someone willing to pay for a -- let's say -- a Chinese ETA clone (about US$50 - 80) for a full maintenance/lube/repair if the watch is only about US$100 complete? A 7750 clone goes for about US$100 - 150 for the movement...The work is the same as for an expensive/quality Swiss counterpart. Needless to say the math is not there.
That in addition to the ethical problem of copywrite, patent infringement, etc.
Cheers,
Bob
On 4/7/2016 at 9:38 AM, oldhippy said:
As its fairly new I would take it back as it must still be under guarantee. Don't mess with it as that will make the guarantee void.
It won't have a real guarantee, it's a "rep" (a  new euphemism).
I'm sorry, you said you bought this replica Audemars from 'InTime'? Can you elaborate on the where and the how? I'm sure you don't mean 'In-Time Watch and Jewellery Repairs'? They don't sell Rep watches, unless it was a staff member selling it to you unofficially, person to person.
I think OP bought from www.intime.co
In my country fake watches are 100% illegal, both buyer and seller can be prosecuted. I don't think the UK is different.
6 minutes ago, Ishima said:
Ah, wasn't aware of this website, and yes i think we have similar laws. It's a shame they're not enforced more, in my opinion.
it's very difficult to enforce. It would mean inspecting a great percentage of packages destined to individuals. It is probably enough that these are not sold highway side like years ago and the number of scams is reduced.
    • I have Bergeon winders #6 and #7. I don't have a handle, probably using a handle it's a much nicer experience but they are perfectly usable without one.
    • They do exist, i had a Lucerne front access a couple of years ago that had a false looking screw down case.  At this stage if you are positive that the case and back are in one piece and the split stem is unsure then start thinking about pulling off that crystal. If its waterproof then it should have an armoured ring but in any case there is some good height on the sides to try a crystal lift tool. If it wont budge then some double sided tape stuck to your bench , place the watch face down and let the tape set for an hour before pulling up. If the crystal has a distinct dome to it look for a good matching surface to press into to get a positive seating for a good adhesive contact. I have even had a small suction cup pull off a crystal before.
    • If it's a push on back then it could have a notch in it for the stem which would mean the wording position would stay the same across all watches no matter how many times the back was removed. I've never seen a watch of this era, even a front loader, that doesn't have a removable back.
    • Rule of thumb I have is that if the dial is larger than the case back (or the thing pretending to be a case back) then it is probably a front loader. Appreciate it's sometimes not easy to tell, but lots of times it's obvious and you kick yourself for not realising it earlier.
    • Geotex, wow on the poor-man’s display back.  Didn’t see that coming.  Thanks for letting me off the hook for not realizing it.  I greatly appreciate your time and advice.  I am trying follow all of the advice people take the time to provide but being a relative novice I am not always sure of exactly how to execute it.  I don’t want to go too far in the wrong direction. I have already found out how that ends.  Your evidence regarding the wording on the case backs is compelling.  It’s placed exactly the same as mine.  What’s the odds that three watches could have case backs removed and replaced repeatedly and all end up in the exact same position.  They are identical except for the fact that some idiot super glued a big nut in the middle of mine.   Now, considering the last comment by Eccentric59, does it make sense to pull the Crystal to check to see if it has a Seiko movement with a release lever before I commit to using pliers on the crown?  Nothing to lose with that approach I guess.   Thanks to everyone again for your time!
