Wittnauer crystal wrench
UrgurTheGurgur
After repairing and servicing my father's great grandfather's Elgin pocket watch(picture heavy post coming of this). I returned it to him this past Sunday as an Easter gift. After dinner, he handed me his uncle's 60's Wittnauer Automatic which hasn't run in years and asked if I could take a look.
The caseback is stamped "Use All Proof 1200 Wrench" From what I gather, it is a tool which compresses the crystal so it can be lifted out. But try as I might, I cannot find an "All Proof 1200“ wrench. I did manage to find This tool on the Bay. Can anyone tell me whether it will work on this Wittnauer?
If you have one of these little monkeys you could try it. This tool is a must for anyone repairing watches. There are many tools for removing glasses. Many years ago many makers would bring out there certain tool for opening their watches, I had many,  this universal tool was better then most.
28 minutes ago, clockboy said:
If purchasing one DON'T buy the cheap Chinese  version they don,t work. Purchase the Bergeon made one.
Thanks clockboy the cheap Chinese ones weren't about in my days. I see a lot of Chinese watch tools on ebay and they don't look very good.
I did have a Bergeon lift tool but at the time was struggleing with low domb crystels so purchased the Chinese one to see if it would work better. However I just found the build was crap & just did not work yes I suppose I could file & dress the claws but what a per larva. As the saying goes you get what you pay for.
Thanks for the advice, guys. I'll definitely be keeping an eye out for a used Bergeron lift.
As to the one I linked in my post. I just thought the Longines one might work for the Wittnauer. Because I believe Longines owned Wittnauer at the time this watch was made. But there is probably only one way to tell. Right?
And careful since a used -- or abused -- Bergeon could be worst than a new Chinese...they won't work, either one! And you will have to dress every claw risking to offset the "balance" of the tool. Still the construction may be better in the end with the used one...Always a gamble buying used, especially when they are not that cheap.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
    • Moved in. Now working out the best place to have things so moving around the room makes sense. The wooden movement testing rig may end up being suspended from the roof with some pulleys and ropes that I salvaged from some alfresco blinds that we replaced. I always seem to salvage things from things we scrap thinking, "I have an idea what I can use these for." I hope I'm not the only one that does that. My wife hates me for it. "What are you going to do with all this crap?" Anyway, here you go. If anyone has suggestions for workflow around a room, speak up. All Ideas are appreciated. The bench on wheels will carry either a laptop or my Samsung table for using with the little camera that is on the tripod for photos while dismantling etc. The small bar fridge in the corners going to have water etc in it and I might move the coffee maker from the kitchen out there as I am the only one that uses it. I want to get an ultrasonic cleaner so I may set up some sort of cleaning rig in front of the glass of the sliding door. Where the grandmother clock is currently standing. I'm hoping that I will be able to transition my working area, which is the table that the stool is sitting in front of, fairly easily between clocks and watches. I'll be doing my best to make sure that tools for each are separatedwhen stored. Logistics. I'll have a bit of wall space for being able to hang clocks if I find some that I wish to keep or hopefully at some time to be able to hang customer clocks for monitoring after servicing/repairs. The clock on the left in the blue pillow slip and the grandmother clock are earmarked for  Jarryd and his wife, Sara. He helped me move the benches in today. And then went on to tell me that ticking clocks drive him nuts. Who doesn't like the rhythmic ticking of a clock? I have a green pad for adding to the bench for a working surface. It is not a cutting mat or one of the Bergeon mats. It is actually a green desk writing mat. Was really cheap and will do exactly what I want, I think. I also have to get the sparkies back that put our new stove in to put some power points on the walls behind the benches. Hopefully this is all going to go well. I'm excited about it. It'll beat having to live out in the garage doing it. The other thing I have to do is cut a circle or square of plastic to go over the bouncing watch or clock part black hole in the middle of the floor. I would pretty much guarantee that anything that sproings off the bench would end up going straight down that drain. 😄      I think I have been on this forum about 4 years and still yet to really strike a blow. That's a bit sad isn't it. Signed up to Mark's watch course and have yet to buy the movement for working on. Have most of the tools I think I will need so now all just a matter of will.   I have to make a crank handle for my Joe Collins spring winder as well and some spring retaining tubes as I can't find where I can buy them. I will be salvaging (here I go again) the aluminium tubing from my old hang glider which I have to scrap as I can't fly anymore and it is too old to sell. All the aluminium tubing is aircraft grade so I am hoping it will be suitable for the winder. I have also been making a bushing tool and I have just worked out that it will work well with my Dremel stand. So another thing that I can turn into a working tool. Don't know if you guys have ever seen the ad about the guy that buys himself a new 4WD and the son says "We're going to need a bigger boat." So Liz is looking at all the stuff we have to get rid of and says "We're going to need a bigger bin." Really difficult to work out how big a Dempster bin we need. Sigh.
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
