14K Gold 1950's Elgin
Karimn51
Here is a watch given to me by a friend. Only needed to be cleaned and lubricated. post-68-0-28291100-1398381401_thumb.jpg. This watch is from the 1950's, 17 jewel automatic. Caliber elgin 645. The dial is cream colored but around the center some of the color is gone showing white. I am not going to mess with the dial. Probably better to have the original versus a dial that has been redone.
I'm with you on this and welcome to the forum!
I love early Elgin watches. Yours looks to be from the days when they stopped using American movements and moved over gradually to Swiss movements. My guess is that the movement in yours is American. I wouldn't mess with the dial either - you can clean and polish away history that way!
Edited by WillFly
Both fine watches and it's nice to know they have gone to good homes.  Thousands of fine watches have ended up in the bin just so the gold case can be melted down,  almost a crime against humanity.  Would be punishable by flogging if I made the laws.
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
