Help with glass/ bezel
Ayup all I've go a problem with a project ive been on with its a Eldore geneve watch that was in very rough shape when I got it for a 99p bid on the bay. But me being me and hating to see a Nice movement and bits of case go to the great watch graveyard in the sky I thought I'd have a go at bringing it back to life. Firstly I serviced the movement which looked a bit of a state but after a long cleaning process (removing rust and what i can only describe as old glue ) I brought it back to life  (couple of picks added) but thats not my problem after spending time removing all the old varnish from the dial which removed its name but that doesnt bother me as its a project. Ive re- varnished the face and blacked the hour markers and 12 position crest . Its what do i do about glass should this case have a bezel that a glass clips into or something like a tension ring glass I have no idea also I can't decide on black or gold hands so if you have any ideas please feel free to reply.
Mick
I hoped that a sonic clean and a little silver cleaner would remove the dirt but alas no. So firstly I added boiling water to a bowl with the dial for about 2 mins to soften the old varnish then it was a case of removing it using pegwood being carfull not to scratch the old silvering then I touched up pieces of silver that had been damaged with citadel paint dry brushed on ( paint on a brush and then rubbed off on a tissue leaving a very small amount on the brush. Look it up on the internet its a common technique for painting the look of metal on warhammer miniature figures) then i ran black ink into the original embossing using a 000 brush very hard to do and a steady hand needed. Then just a case off varnishing with a couple of costs of testers dull coat varnish.
Thought it would need a bezel but as you say hens teeth I need to find a 27.8mm gold bezel . Given enough time sesrching the internet usually grants your wishes at a price :smiley-face-laughing:need one of these in gold plate.
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
