Clothing
MWNAWR
Stroppy, remember the thread "Reducing humidity inside the watch" which I started in January. I cased up the watch in this humidifier grove box I made. So far the watch did not fog up anymore.
Dadistic, it's home made using a plastic aquarium, kitchen gloves, two top part of plastic cookies containers used as holes for the gloves to attach on, cut two holes on a transparent plastic bag, dehumidifier substance, a mini fan to speed up the dehumidify-ing process and a digital humidity meter.
Edited by steven
Dadistic, it's home made -
Hah! No wonder I couldn't find it :-) You sure did a professional looking job. Saw a similar lab glove box for sale for about US$400. I remember you mentioning solving your humidity problem, but I figured you'd just dehumidified your entire workspace.
Last time I had condensation in a watch, I took the back off and heated it up with a hair dryer before I closed it again. Seemed to work.
Thanks!
Thanks!
I have "rescued" a couple of smartphones for the kids of friends of mine using the hair dryer method.  You could do it if the owner had not attempted to power on the phone after the inundation.  I would take the battery out...unscrew the motherboard as best as possible and then put the works into a bucket and gently heat the air within using the hair dryer.  This method worked with about half of the flooded phones...the rest were DOA no matter what I did.
Have you tried a bag of rice? Bury them in rice and leave in a dry place, it should work too, the rice will absorb the humidity.
Yep...that works for phones that have been in the pocket during a downpour but not for ones that have fallen into the dunny...etc  (don't laugh...it happens more often than you think).  :D
Edited by stroppy
  • 5 weeks later...
Friend gave me an old cloth to clean my car. The cloth turned out to be a very good cotton apron. Its old but well made. I now use this to protect my clothing and watch parts when I am repairing.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
    • Yes I understand that. What I’m asking is, after the hands have been fitted, it’s been checked that the hands do not touch etc. then I need to remove the stem to fit the movement in the case. I have the push type, I need to turn it upside down and push the setting lever post and pull the stem out. But of course the dial and hands are in place and I have a glossy dial with lume dots and I do not want to cause any damage while it’s upside down pushing on the post of the setting lever.
