Quartz Movements
Hello, a friend's daughter has a Gucci 100l quartz watch  which is running erratically. Inspection of the movement shows the stem removal button  looks a bit damaged, and I can't remove the stem, but it will probably come out with a bit of fiddling (via the arrowed hole?). When the stem is pushed in for normal running it doesn't fully disengage the hands and the watch may or may not run. I don't know much about quartz movements but I see hundreds of them in the Cousins catalogue usually quite cheap. Is there a system of reference that allows a movement to be replaced by a new one of the same size, hand fitting etc? The movement may be a YA100503 as this is quoted for similar Gucci watches.Photo of the movement attched, I can't see any numbers.
post-1266-0-70123200-1455705922_thumb.jp
spot on, well deduced.  Its not the original stem and only holding on 3 turns to the crown when properly adjusted for depth, now held with Loctite. There was a lot of "felt" around the tube also stopping the stem pushing home.
Looking at my fuzzy photo I had a better look with a microscope and found Ronda and 1032, this movement is currently listed by Cousins for about £12 (less vat & pp), might be cheaper to buy one rather than replace the stem! Makes you think about "designer" watch prices and what's inside them.
I'm still interested in the interchangability of quartz movements, are the Chinese ones copies of Swiss types or are they all different?
    • I assume you're using 9415? the concerned with 9415 and I'm attaching a PDF from Omega is too much can cause a decrease in amplitude. This is why you look at what they do they go to extreme lengths to put extremely tiny quantities. so as you've discovered proper lubrication of the escapement increases the amplitude. We've seen it on this group where people are having typically newbies issues and I will ask if they lubricated the escapement the usual answer is no they had not because and once they did they saw spectacular improvement. one of the amusements with lubrication tends to be so many variations. For instance I was in a classroom once and the students all came from for the most part accredited schools in watch repair. So the instructor asked how did we lubricate our escapement's and I don't remember the actual quantity but it's really quite amazing how many people can interpret slightly different ways of doing the same ask. Of course the instructors method was the approved one. This was the place a drop of oil on the impulse face of the exit stone. Allow one third of the teeth to go by and place another drop then another third and your escapement should be lubricated. But sometimes and yes it will show up in the timing machine you'll see in your regular line because if the oil didn't transfer all the way around to the other stone that does cause a issue with the timing machine. Oh but when I was in school we were using 9010 as 9415 did not exist yet although 941 did which is an oil recommended for escapement's. it has to be dissolved in a proper solvent with the right amount of concentration as you want a microscopic layer on whatever your treating. My understanding is the vapor process is the very best but the vapors are not good for human consumption. The reason why the vapor process is nice is that it puts a very very thin coating on versus dipping in a solvent which can vary depending upon the concentration.   8645_WI_40_rules for lubrication cousins.pdf
    • A modern restorer would probably try to inject adhesive as suggested and then weight the repair down. Some damp might have caused the bulge originally.  Traditionally the veneer would have been sliced and glue eased under the two flaps then again weighted back down and refinished once it had cured.  It doesn't look like just an adhesive issue, more than likely expansion of the veneer, worse case it needs a slice taking out. Try some gentle heat on it first , inject glue and weight, to see where it goes.
    • I have seen several mentions of steric acid, how do you use this, I have only seen it in crystal/powder form?
    • Hi @Michael20 I am no furniture man my self but it’s just bits and pieces I have picked up over the years. It just takes patience when dealing with things like the cases but most are veneered plain wood. When they get damp and open up that is a problem
    • I often get an amp drop after i oil the stones with 9415, not sure what difference can be achieved with oiling the teeth.  I guess the oiling surface is very small on a tooth as opposed to on the stones a larger drop might have more drag as the teeth plow through it. I oil with a bristle from a brush now, strangely enough the last movement i oiled five escape teeth and the amp was much higher than i usually get , coincidence ?
