Top Class Pocket Watch.
For pocket watch fans this "Patek Philippe" must start the juices flowing,  they don't come much,  if any, better.  Whoever gave it as a present must have had plenty of money,  be interesting as to how much it would fetch at auction today.
The devil is in the detail, isn't it. The hands and dial are beautifully crafted, as is the case. I see it has eight adjustments - presumably for isochronism and positions. Some of my US Railroad Grade pocket watches have that level of exactness, but without the fine detail of the Patek movement.
I had a look on the net and it looks as though the Patek could be mine,  or one very similar,  for around the £4,000 ish. mark,  less than I thought but more than I can spare for a watch.  I would be very interested if anyone knows how the porcelain dials were made,  I think they may have been hand painted,  in which case they had a very steady hand indeed.
As the start of a small collection I have just bought an "Illinois Bunn, 17 jewel,  temp + 5 pos."  the movement is a work of art and definitely deserves a display back.
Edited by autowind
Will,  Your Bunn specials are just that, Special, they are works of art,  fortunately for us the whole world does not know this,  as if they did the price would increase 10x.
Timing for positions and temperature is another art,  as you can imagine getting it right for one position will most likely upset it for another position which you have just got right,  very clever work.
    • This is not rare at all, the dial code and case code don't usually match.
    • Good question!! Anyone know of a substitute movement??!! 🤔🙏
    • Interesting issue that I just noticed: this Seiko 5actus Watch from 1977 has a calibre listing on the dial of 7019-8030R but on the case back it says 7019-8010!! Like a mis-printed coin, is this watch therefore worth a lot of money for its rarity?? 🤪😲🤔🤪
    • I wish that was the case. The Aegler movements used in the early days by Wilsdorf & Davis (for brands like Rolex and Rolco) came in several sizes and without designated calibre numbers that survive.  They become a bit easier to identify during the 1920s. Below is an Aegler-Rebberg, 25.74mm in diameter. It’s from a woman’s Rolex wristwatch. Stamped Rebberg and 500 on the dial plate (but it isn’t a Rebberg 500, it’s the wrong size).  I’d be interested if anyone can identify the movement.  It is based off the Aegler Nr.1, circa 1903, but they based many many calibres of different sizes on it. The closest I have to a positive ID is the  ‘Rolex Nr.50’ circa 1917, but no dial side images or movement sizes are available in the references. There are identical looking movements in many sizes.  The 25.74mm of this movement is a particularly strange size for the era, it equates to 11.41 lignes.      Best Regards, Mark
    • It looks like this movement comes with a number of different shock settings. Emmywatch shows that it comes in versions with no shock settings, 'Incabloc', 'shock resist', and 'Supershock'. Perhaps the different settings position the impulse jewel/roller table in a non-ideal position relative to the pallet fork/guard pin. Are you able to check under high magnification if the pallet fork and roller table are able to operate without any interference? Just for fun I took a look and I have one FHF 70 in my collection, a West End Secundus with a non-shock protected FHF70. I had a note with the watch that said, "Movement is stamped 'FHF 70', but the FHF70 looks to have sub-seconds instead of center seconds movement (??)" but that a google search turned up both types for this movement. EDIT: I just took a look in my parts drawer and I have a few of these movements, both in center seconds and sweep seconds, but they all are non-shock protected.
