Seagull Sg2903
Legarm
I don't know, Keith, but it seems Chinese movements are short on documentation and spare parts...I'd say impossible to get either unless stripping a good movement from the parts needed. I hope somebody proof me wrong!
Cheers,
Bob
I have emailed Seagull for the part, but I think that will fall on deaf ears.
I will strip it down to the barrel and cobble together a spring. I was trying to avoid stripping   the hand off as the dial is a matt finish that I don't think it would take much to mark it.
perhaps someone has a solution, a new mvt is £94, so not a cheap one.
I've just had a look at one of these Keith, there's no easy fix. If you are lucky you might be able to make one from a fine guitar string.
I shall start it tomorrow. I have some circular Click springs, the broken one fell out so I know the sort of shape.
I shall start from the top and work down to the Barrel Bridge, then it will all become plain and simple....... I hope.
The watch has had little use so I expect it was either a faulty spring or they are prone to this.
If I remember I shall take some photo's, for anyone interested in seeing what is there............
All done..... Not such a hassle as first thought.
Few parts for the Chrono to take off and remembering to zero the watch prior to dismantling. Click spring was a basic circular, with two upstands, so was able to fashion one to fit from my spares cabinet.
All took about 1 1/2 hrs, with putting everything back together with a nice new Italian Leather strap.
I'd make one out of an old Spring mate, just find one of the right diameter & the right thickness stretch it apart & cut to suit, fold the ends up! Make them over long & cut to suit! Give it a go mate! You've nothing to loose!
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
    • Why cut the paper, cut a square around the image and grind to it.
    • I did try that last time Rich , i traced the image from the Bestfit book which is the actual size. But its more difficut to cut the shape from paper than it is to grind the steel to shape. This way is pretty easy and the final shaping is done when fitting the part. There are a couple of things i will do differently next time, clamping the 2 pieces together with a drill press will help to hold while scribing the shape in. This was a bit tricky having only one hole, if using the pins and cork the drill size needs to match the pin diameter so there is no movement at all from the template. This movement hasn't finished frying me yet, damaged thread in the plate crown wheel hole and two rubbed in cracked jewels, thats gonna be much more fun.
