It would help greatly if we knew what watch it is and also a better hi-res pic of the caseback.
From the provided pic I suspect a squishy ball will do nothing, it will need a blade/wedge/case knife.
It looks like a screw type. If correct it will depend on how tight it is for the method used to remove. The sticky ball method is not good for the really tight one,s. Some members have attached a bolt to the back using supper glue undoing with a spanner then cleaning the back afterwards.
Last year I bit the bullet & purchased a Horotecc case opener which is the best opener for the screw types, but you still need the appropriate die,s for the various makes.
A better pic will help.
Thank you all for your kind and sorry for poor photo. Its is a homage of Rolex. There are serrations on the case back and as you suggested I'll need appropriate die to attach to it
If not other opener/dies available, a Jaxa type with the right tips will open it. Beware of some Chinese cases which have a press on back that look like screw on.
If the case back has serrations does that mean your looking for jaws with a triangle end that you attach and turn anticlockwise? I've never come across this type of case back
Sent from my SM-G900F using Tapatalk
here is the correct tool for Rolex type case backs
550f42b6-3b30-4a16-a2fa-a265da3c4768_zps
Edited by Andyclient
