"prestige" Watch Brand
Ash
Hi,
I have a customers watch that I need to replace the dial.
The Brand is called "Prestige" but it's like they don't exist on the web.
Image below if anyone can point me in the right direction.
Many Thanks in advance
Ash
post-1752-0-13324100-1453114875_thumb.jp
    • Thank you!   Yes I did. I did not notice a difference. Although 9415 is advertised as a thixotropic grease (and I did had high hopes for it), the only advantage at this point I see is that its “easier” to apply than an oil (if one does not use epilame). But this is subjective, I guess. What I did notice though, if you apply a bit too much grease, that definitely slows down the movement. Oil in this case is a bit more forgiving, as its super thin, and it would usually just spread out.  Again, imho.
    • Mark keeps a close eye on his forum. I'm sure if you asked him he will reply, he might not do it right away but you will receive his answer.
    • I kind of think the same, the surface under the oil is the same as the surface around the oil. Can epilame both repel and attract , that doesn't quite make sense in simple terms, but is it more complicated than that. When cohesive forces within a liquid are stronger than the adhesive forces of a surface then surface tension is high causing the liquid to bead up. So  an applied epilame coating reduces the adhesive force of a surface inhibiting a fluid to wet the surface. So i guess no epilame cannot both repel and attract . If something is keeping the oil in place on top of an epilamed surface then there must be another reason for that.
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
