Evening all this is my uncles watch which has a broken jewel on the escapement wheel I don't have the kit to replace so wondered if you could identify the movement to I could source some spare parts!
DAB6EC4B-C1B7-47FB-BDF4-DF3B7EEFE41D_zps
6EF2D77D-128D-4F89-AB51-98462D6C2D21_zps
In my experience the jewels are sold by size, not calibre.
You would need the outside diameter of the broken jewel and the pivot size. It is possible to fit it without a jeweling kit if you are careful (I have fitted them before using my staking set).
Sorry I can't be much more help - if I had one here I could measure it up for you to tell you which ones to buy, but I have checked and I don't have one :(
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
