I am partway through repairing a Seiko 7006A watch. Putting it back together again and having an issue with power. When I put power into the watch, it is suddenly released. The click is one piece, working by it bending, so theres nothing much I can do about the click so surely its something else? Please bear in mind I'm a beginner so dont roast me too hard! Train of wheels run free, pallet fork runs free, and balance runs free.
Here is a OneDrive link to a video of the issue. https://1drv.ms/v/c/d19df1b57085da7d/EfHB20218tBErJQh_SInxQ4Bb8DEdG33GNnprM2mxowWYg?e=efAnUc
Attached photos:
How the click is attached
Overview of movement
The clickspring is not the problem. When the power is released, the barrel turns. That should not happen. The pallet fork should be blocking the train of wheels while you're putting some wind in.
Try again and focus on how the pallet fork and the escape wheel interact.
  • Like 5
If when you wind the watch the train wheels spin as @caseback mentioned check the escape wheel pallet engagement and also the engagement of the other train wheels, you may have one upside down .
Did it work ok before you worked on it.
Just a reminder we have a section just for these sort of things.
https://www.watchrepairtalk.com/forum/74-new-to-watch-repair-safe-zone-for-learner-watch-repairers/
When reassembling a watch as others have pointed out it's wise to check the functionality of components as you go. So in other words before the pallet fork goes in or even the balance wheel you can attempt to wind the watch and make sure the gear train spins nicely. Then you can put the pallet fork in wind up the power and see that the pallet fork snaps each time you push it back and forth in other words things need to be done in steps not all assembled and then discover we have a problem. Although unfortunately sometimes that does happen and sometimes the problems do not show up instantaneously.
Yeah ok, probably is the escape wheel.
Yep, that part worked ok before I worked on it.
Yes I did do this, but something must have slipped past my eye, train of wheels was smooth, pallet fork snapped, and balance pivoted freely.
Thanks for your help everyone, hopefully this week I'll have time to sort it out.
It might be the arbor of one of the train wheels slipping. Remove the balance wheel but leave the pallet fork in place and wind until there is slippage. Obseve which wheels turn and which wheels don't.
And yes, the most obvious. Is the mainspring wound in the correct direction?
Pallet fork and balance are 100% fine.
All wheels except escape turn.
Is my escape wheel pivot broken???
I cant see anything in jewels but i have no microscope, only a cheap 20x loupe.
The escape wheel pivots do not look broken, though the upper one (left) could be worn down short? How about the escape wheel's jewels? Are both intact and what is the end shake like on the escape wheel and pallet fork?
Phew thats a relief the pivots are more or less ok.
Apologies dont have the best camera setup for closeups.
I just tried putting train of wheels together without escape and it runs very nicely.
That means that the escape wheel's abor is loose. The wheel remains stationary while the pinion is spinning.
    • 1. I think the pivots look pretty good and I wouldn't worry about wear. 2. Yes, I think the hole jewels should come out for cleaning, complete with their spring setting. I don't have experience with Rolex but I've seen this spring type setting in another movement. They may be stuck in with old dried oil. 3. Yes, I think the overcoil is out of shape.
    • Yes, I'm looking at this option. I have a good friend from childhood who happens to be a goldsmith, and he would certainly be able to tackle the second hole to my specifications. I usually avoid this path because, since he deals with gold pieces, every time he stops to help me with "frugal" parts, he is objectively losing money. I agree with you. Even though I couldn't justify paying this much for the set (they only sell the whole set or the sole case tube), I understand the price tag. The trouble with this particular stem set is that the most common use case for it is the Technos Skydiver, a watch whose price certainly justifies 220 USD for a brand-new stem set.   I have messaged them only on the surface, without specifying my needs. They already stated that they don't sell the single female part, only the full set. What I still don't get is the need for a second hole. Is it supposed to be some sort of regulation, meaning that I can fit the head of the male part in any of the two holes to adjust the pressure of the spring? Does this mean that a single-hole female part has a chance to work with my setup? I'll later test this hypothesis while continuing the assembly of the movement. Some photos are attached. Can you judge this bracelet? It was dirt cheap (4 USD), genuine leather, wife's choice. I have just realized my dial is upside down. lol
    • Hello from chilly Brazil! I just bought a couple of watches and this watch came with them. While perhaps not worth much I'd like to try to find out something about it. Googling comes up with with the name Gerald Genta, and I see from internet searches he's made some nice designs (perhaps an understatement)! Also some cartoon designs but I can't find anything like this anywhere, so most likely not his!  Googling Royama I see that some famous people liked his watches and also the Royama watches. Two questions; 1. Can anybody tell me anything about this watch and its background? 2. How to get the base off to let down the main spring which is fully wound. I gently tried prying it but nothing, I see there is a button but have no idea if it is functional for removing the back or anything else. Screwed back maybe? I really don't want to break the back or the watch with too much pressure and haven't looked up the properties of Grilamid!   Probably not much of a watch but it peaked my curiosity and I hope somebody might be able to help? The auctioneer sold it as a psychedelic acrylic 1960/70 Royama watch overwound! All the best...Jules
    • What do you use as pivot drills @nevenbekriev?
