21 minutes ago, LittleWatchShop said:
What the poster did not understand is that this is a watch porn site.  We want to see pictures.
Yes we want to see pictures. Anything that's a interesting repair we want to see that also we are visually oriented on this group. The problem is the original posting person has a very clear idea of exactly what they're doing exactly what the problem is and totally cannot comprehend at all why we would question anything at all related to the question. So the concept that we might want to see the actual watch is beyond their comprehension even though it is a watch repair discussion group and we always want to see the watch we like seeing pictures especially if their watches and clocks. Even better if the watches and clocks are naked as I really like seeing the mechanisms of clocks and watches.
There are rubber straps with curved ends available from AliExpress.
Pictures would have helped us a lot. I've never heard of Wise watches until this post. It's a microbrand from Thailand. I believe it's manufactured in China. So chances are there are straps from China that would fit.
https://imgur.com/a/idd0ZQz
Here are the photos. I still don't know what they will inform anyone of. I've tried to provide every angle.
First image is how it sits without being on - you can see the gap. Second and third are how it SHOULD sit - perfectly aligned with the lugs against the watch.
Fourth is the area I would be putting my spring bar through. Fifth is the lugs, to see if anyone can determine the distance or recommend a strap that would fit.
Sixth is how it SHOULD sit from the back. Seventh is how it sits with the gap from the back.
5 hours ago, AndyGSi said:
It wasn't clear to me on the first read if he was even using a curved end strap, maybe I should have read it more throughly but never expected that response.
I did go afterwards and look at the offending watch and noticed how far the spring bar is from the case.
I've had similar issues in the past and on most occasion found a strap that worked.
On the occasions that I couldn't I used a heated syringe needle in a drill press to melt
a new hole through the strap and then used a spring bar tube to fill the old hole.
The thing I find strange is to pay $300+ for a watch and then say the strap is cheap which I think says a lot about the brand.
My pet hate about these micro brands is how they always show inflated prices with large discounts to make people think they're getting a bargain.
What's strange about buying a watch that ends up having a flaw? I'm not happy with the strap quality for any price. But I'm used to replacing straps on my watches - what makes me upset is that it seems to accept a nonstandard strap solely due to the lug holes being placed wrong. THAT'S a major issue. If I do get a new strap on it I won't be able to swap it out.
A syringe needle seems rather small, would I need to get a larger needle? And then it's as simple as (attempting to) throwing the strap in a vise, heating the needle, and pushing it through? What method did you use to heat the needle? I'm picturing just a lighter. I appreciate your suggestion and your help!
Edited by Xonax
The problem is everybody approaches problem solving differently. While it seems crystal clear to you because you're holding the watch in your hand and you can see the problem. Unfortunately everybody in the world is different for some of us one picture's worth 1000 words and Once we look at the picture we can grasp the problem.
Actually that's clever marketing because you're forced to purchase their straps. A lot of watch companies do clever things to force you into only purchasing their items.
I don't think there is an easy solution here. If you do manage to make a new hole through the strap, it will be so close to the original hole and tear through eventually.
Drilling new holes in the lugs to reduce the gap might be an viable alternative.
Why not buy original straps from the manufacturer?
this I would think would actually be the best solution as you wouldn't have to modifying future straps.
@Xonax thank you for posting photos. They were well taken and helped us to understand the problem more easily.
We have never seen such long lugs in modern watches and would have had a hard time visualizing what you put in words.
Many of us in the watch repair circle are a bit dyslexic. So pictures are really a help.
Watches that were bought with steel bracelets can have the opposite problem,  of not having enough space between the case and the lug bar to fit in a leather strap. Thin hollow end links  often fit close and the lug bar won't allow a leather strap to fit or take a comfortable wrist shape .
This is the type you need in either 15Gauge or 16Gauge which should be 1.6mm O/D so you can use a 1.5mm Spring Bar.
You need to sharpen the tip slightly and I heated with a mini lighter blowtorch.
I think there are better options from the strap you're starting with but I'm out most of the day so will see what other people suggest.
This was solved as mentioned above by using a spring bar tube to fill the existing hole.
Edit
Just found you can get 16Gauge Hypodermics which would possibly go through better.
And body piercing ones maybe even better.
Edited by AndyGSi
To make this mod to look good seems challenging. Drilling new holes in the lugs would be a reach. You may just order a variety of straps and see which one looks the best and return the rest.
Sell it on ebay and find another watch.
12 hours ago, clockboy said:
It looks like to me that this watch was designed to have a metal strap with a end piece such as this.IMG_0982.jpeg.55cda665ef2b33c1ee87fe3a98368f8d.jpeg
I have another Microbrand watch where this was the solution. I removed the metal strap, kept this gap closer piece, and attached one of those straps where the middle is extended, like this. That might be the solution here as well. Of course I was not provided any of those end pieces with this watch. Step one will be to ask them if they have any, but step two is - is there a generic version of this product I could try? Do we have a name for it? My Google Searching is only finding those ends that go from 18mm to 20mm, or vice versa.
Edit
This will be my next project for sure! I was given some extra bands so I have some room to play around with. Inserting a dummy bar into the old hole is a terrific idea as well! The holes on these straps are already too big that I need to fill the space with extra material just to keep it tight. No idea if that was an error or if it's just expecting a really thick spring bar. They go through decently easy when heated?
To be honest it's a few years ago and think it was a struggle.
I've got a friend dropping some piercing needles off with me tomorrow so will give them a try with and without heat.
Search fof curved hollow end links.
To keep all my options open, I ordered one of these that matches the make and model/size descriptor of the strap I ordered. One of my bonus straps is already ready for this kind of cutout, we'll find out how it all fits.
out of curiosity today when I went to work I asked about the problem. The first response was it sounds like the watch was made for a metal strap.  so in which case as already discovered the spring boreholes are too far back. I do believe on the website they did have metal straps.
On 4/14/2025 at 10:10 PM, AndyGSi said:
So despite not have the correct drill and setup here at home the piercing needle did the job without any heat.
I don't know when I will need this information, but thanks to this strange story I guess I will always remember this solution.
Thanks Andy. 👍
Nailed it Andy 👍
1 hour ago, MariusJacob said:
this strange story
It kinda was, but had a happy ending all the same.
