Canon Pinion Problem
syfre
Hello dear members,
I need some help about a problem i have on an old Illinois 18s
When i set the time, the canon pinion raise up and disengage the setting wheel.
I think this is a pretty common problem on vintage pocket watch, not the first time i get that.
As the CP was very tight i tried to loose it using a small broach, it help but not resolved totally the problem.
i would appreciate if anyone can help
Regards
Have you put between dial and hour hand wheel a washer? There should be special shaped washer installed to crate small tension to stop hour hand wheel from rising. Im not sure if I understud your problem correctly from your description...
Edited by Rafal
I have read that the only way to fix a over zelous indentation or as I had just too many indentations to create the friction is to broach them out. However it was not possible so I had to purchase a replacement one. Being a vintage pocket watch it will be difficult to source one.
There is an excellent artical (pp209 / 211) in one of Donald Carle books "Practical Watch Repairing" that covers this subject.
Thanks for the answers,
yes there is dial washer but a dial washer is for preventing the hour wheel to raise up.
Thanks for the Donal Carle tip, i don't know why i missed it ; my opinion was to turn a shoulder on the arbor at the position of the snap, this what DC describe. But before altering the arbor i wanted to be sure.
There is an interesting paper about canon pinion friction here :
http://elgintime.blogspot.fr/2012/01/mechanics-of-canon-pinion-friction.html
when reading it after DC explanations it become clearer.
