NewB
Thanks John, I'll try a new circuit as well as lubricate the movement.
Sorry if anyone feels I reacted incorrectly, thinking is a timely, healthy discussion about the limitations of AI but less so about Rolex real vs fake. There’s good information on that, too…thank you…
I have the rubber ball and the 3 finger dish type of remover but it wouldn't budge. I did hold the compass legs right down near the points so they are ok. Never come across this type of caseback before. Also never come across a Rotary with an automatic movement which doesn't say so on the dial....
Solved it!!!!! A post on the underside of the operating lever return was sitting on the wrong side of the spring. Due to the design it worked a bit, but not properly. Refitted the lever while retracting the spring and now it does what it should! I think you learn more if you solve a problem yourself rather than being told the answer. Now it's back in the wash, and see if I can get this thing up and running!
I asked ChatGPT's deep research mode about blue screws in Rolex without pointing to any particular source. After thinking for 10 minutes (deep research mode), it quoted your earlier conversation with ChatGPT: We are slowly breaking the Internet, post by post. Forums, populated with real people, are crucial!
