Shot for Channel 4 in 1991, The Watchmaker, is a 10 minute documentary which glances at the life of Clifford Norman Bowler (1899-1993) a long-standing English watchmaker and definitely someone many of us would have liked to meet.
post-1450-0-99328100-1448830147_thumb.jp
Mr. Bowler belonged to the precise profession for over 70 years until his death at 93. Initially working for others in Manchester after he left the army, he set up his own repair shop at 54 Mill Lane, West Hamsptead, which he acquired for 100 pounds and run for over 67 years. Today there is a plate commemorating him at the entrance of his former premises.
post-1450-0-87196900-1448823211_thumb.jp
In the film he can be seen at his work bench smoking a pipe or inspecting watches with an eye loupe and at the counter taking several orders from customers (cleaning a pocket watch, changing a strap or a pin). He recounts for the camera his beginnings and how he moved to London, as well as remembering relatives. When asked about the secret of his longevity, he confesses this to owe to a contented mind, regular habits and a peaceful life.
Sadly he did not leave any followers: 'All the knowledge that I have obtained and learned during over sixty years that I have been here, it all comes to nothing. I can't pass my knowledge on which I'd like to'.
His shop, still vacant more than a decade later after his disappearance, symbolises the emptiness left by an irreplaceable man.
There is more info about him in this article: http://westhampsteadlife.com/2014/01/15/a-moment-in-time-on-mill-lane/9921
If you ever met this man or heard about him, your comments could help to honour his memory.
Great vid. He must have accumulated a vast amount of knowledge with 60 years of watch/clock repair. Working with no finger cots & smoking  a pipe while he worked amazing.
fascinating video. all of that knowledge and experience - gone. i wish i had it to do over again. i would like to have been an apprentice in a situation like that. he seemed a lovely old chap.
Great post Edmund, and loved the video. Brings back memories of an almost identical shop when I was a kid in Ireland. Bit sad when he talked about the loss of knowledge. Really makes you appreciate what Mark does in his videos, as this is my only form of any training, the rest is trial and error.
  • 4 years later...
Reading the Wikipedia-page of actor Norman Bowler, he seems to have honoured his father 'after all',  by naming his dad's trade and former location in his article.
Best regards,
FdH
  • 2 years later...
My girlfriend just bought this properly! We are currently ripping out the interior to refurbish it but the plaque in the picture above is staying. 🤓
  • Similar Content
    • Looked into this some more and I believe that some of the increase in rate is attributable to the drop in amplitude after 12 hours off wrist, from 300 to 275 degrees horizontal and some is due to the lower temperature (38 to 18 degrees). I can see that approx 3 to 4 seconds a day is attributable to each. I can be happy with that.
    • Link below shows the tool used to push the stud out. You can make the tool , just file a screwdriver to this shape.  https://www.esslinger.com/bergeon-16918-etachron-stud-remover-screwdriver/ There are vids on YouTube showing how the stud is to be  push out. Shouldn't get over creative, just go by this approach.  Good luck.
    • I tried pushing to dome the washer in and had no success, but stuffing it full of o-ring gaskets worked much better than I expected. It takes some pressure but not as much as you might imagine, but it does take patience ... and a couple of dozen small gaskets. I used the pendant tube of a watch case to stuff the gaskets in as I didn't have a way to machine a tool to suit.
    • I can't answer your question, sorry, but you probably don't what to transfer the spring to a new wheel. Springs and wheels are paired ("vibrated" together) to get the right timing and transferring the spring to a new wheel is quite likely to see you minutes per day out with no way to correct it. Some may tell you to replace the balance staff, but if you're a beginner you're probably better off sourcing a replacement "balance complete" if you can: staff, roller, wheel and spring already assembled as a unit.
    • I'm sure it's the ancien. My measurements: A = 342. The slight bend in the pivot would make much less than a thousandth of a mm difference to this so I don't think 348 is plausible unless there has been significant wear on the pivots. B is hard to measure without first removing the balance wheel. I measured to the other side of the balance wheel as best I could (263) then subtracted the thickness of the wheel (69) to get 194. This could easily be three or four hundredths out, so 195 looks right. (196 could also be right.) J couldn't be measured. I did my best to measure where the balance wheel has been riveted on and got about 95, so 85 before riveting is plausible. (60 is not.) G again couldn't be measured without first removing the roller. I get 37 where the staff emerges from the roller so 41 at the other end of the taper seems plausible. (43 is also plausible to me.) K = 60. (Definitely larger than 55.)   I've never replaced a balance staff; it'll be a new adventure for me. I'll have to read up on how to maximise my chance of removing the old one without damaging the balance wheel without having access to a lathe. I also need to explore how to remove the roller without damaging it. I won't actually place an order until I've gone through the rest of the movement. With the number of issues I've already found, I'll be amazed if I don't have more surprises in store. There are some watch part suppliers in Australia but nothing like Cousins or Otto Frei or Jules Borel. AllTimeCo is fine for basic parts for modern watches: batteries, bands, some crowns, stems, seals, movements, some tools, etc., but not really anything for vintage watches. Australian Jewellers Supplies is similar. Cousins charges about £9 for shipping to Australia which is about AU$19 and not too bad (considering Australian parcel post is $11) but I still want to minimise the number of times I'm paying it. I need to explore other options closer to home. There may be something in Singapore or China that would have what I want and ship it faster/more economically.
