Hi guys, I'm currently servicing a eta 2784. I would like to change the mainspring but i can't find a new mainspring with barrel. So i was wondering can i drop in the eta 2824 mainspring with barrel inside? I have one 2824 mainspring with barrel lying around and i compared, they both looks the same, have the same diameter but the thickness is different. Apparently, the 2784 is thicker while the 2824 is thinner. This explains why the 2784 has additional 6 more hours. Thank you very much :)
The GR spec for these springs is as follows.
2784:  H1.45  S 0.13    L420  Dia. 11
2824:  H1.25  S 0.125  L420  Dia. 12
The big difference is the height which might cause fitting issues with the barrel arbour & also there is a reduction in the real force given.
A GR 4011 or GR 4013-1 would be far better matches or the one Cousins suggests GR3149X.
Personally I only go away from the correct spec spring if I have no other option. For a cost of £7 odd I don,t think it,s really worth the risk.
Hi clock boy thank you for the reply. Then what about its canon pinion, second wheel and hour wheel? Is it the same as 2824? Because i have a h3 2824 cp, hour and second for 2824 and i would like to put it to increase the hands height. They both looks the same, have the same diameter too! Thank you!
I do not know that & I expect few would. One must ask why are you increasing the height of the hands?
Because the hand catches each other. Also the hour hand is too near the dial. Scratching the dial a little bit. I just tried putting the 2824 second hand wheel. So far when I'm testing the freedom of the gear train it works. But I'm not sure will it works when i put in the balance or if it does, not sure will it causes any long term effect like the gear scratches other gear or something.
...are you sure that the dial is sitting down properly on the movement?
Is the movement & the watch case / dial original or are you fitting a different movement into the watch. If so the cannon pinion could be the wrong height.
The other issues could be the dial not sitting correctly, the hands pushed too tight against the dial or bent dials. A picture might be of some use so we can give some sound advise.
Its ok as i'll leave it as it is. Actually i wanted to put the 2784 into another watch case. But i changed my mine. Thanks for the help all!
    • Well, as I have said not once, for the beginners in watchmaking, the hairspring, especially when there is overcoil, is the source of the most of the problems. This is the case here too. The end shake... I told You to regulate it by bending the cock. If it was done, then would be no wondering if the shim is seated correctly every time. You still have to understand how much end shake is normal and correct. One exercise for this purpose:  remove the hairspring from balance. Put the balance in the movement with the cock. Use thin sharp pointed tweezers to grasp the balance staff  where the hairspring collet seats and try to move the staff up/down. The amount of movement should be more or less as much as in escape wheel or pallet fork arbor. In the same time You will see how easy the balance rotates when it is free and without hairspring. Moving the balance up/down by holding it by the rim is not the same, as it forces it to tilt and some shaking may be result of the radial free play of the pivots in the  bearings even if there is no endshake at all. Of course, You can grasp the roller too. You can also grasp the rim, but observe the staff movement, not the rim shake. One should be able to check and say if there is end shake and if it is normal without hesitation, no matter if the movements works well or not at all, and not to wonder if the reason for the not normal working is endshake. Now about the hairspring. You spring is touching somewhere. The fact that this slight lifting of the stud changed the situation proves it. The spring probably touches the arms of the balance, but You are the one that can look at the spring, so it is up to You only to find where it is touching. The spring should be parallel to the plane of balance and thus on equal distances from the cock  or from the balance arms in every position of the balance when it rotates. The coils of the spring must not touch each other. The overcoil also should be parallel and not touching the cock. The spring should not touch (be on some distance from) the regulator pins or the stud bottom. All this must be true also in DU position, not only in DD.  This is achieved by slight bending and twisting close to the stud  or of the overcoil.
    • Revue was a brand name owned by Gedeon Thomman - long history - 1961 they combined Vulcain, Marvin and some others then it gets complicated. Heavily into aviation instruments and also still assembling watches. Good website with history. Sellita movements and £1400. Back to work..... Thanks guys.
    • Still searching - the Revue GT31 is virtually identical, the Revue 31 has the swapped crown wheel <> barrel as in the other listing.
    • Up above you asked a question now you have the answer. Well at least one of the answers why should give you a complete servicing auto wash that just needs possibly may be a minor repair? It's one of the frustrations I have with repairing pocket watches occasionally they look like they might just need cleaning but along the way additional complications can come up. Or even after it's all serviced casing issues will come up. Where I can never really give anybody a hard clear answer of when is this watch going to be done other than the say when it leaves whenever that may be.   One of the annoying thing is in watch repair is the lack of proper technical documentation. So for instance for the 3135 there's a really beautiful color document explaining everything except does it really explain everything? Often times watch companies have supplemental information on specific tasks. They definitely have supplemental on lubrication. Or Omega will have general instructions sheets for specific a grouping of calibers covering well stuff like this unique situations that require either changing components or special lubrication or something. So in the case of Rolex to does upgrade components it would be really nice if we had the supplemental information that we do not. As conceivably this was covered the writer problems here might've been covered with upgrade components or some documentation specifying lubrication that would be better somehow etc.
    • Is it Wittnauer symbol? https://www.watchuseek.com/attachments/factory-names-jpg.593897/
