Eta2836-2 Stem Woes!
By hofnerpres · Posted
I've had a couple of Omega Auto's for service lately with the owners saying " The Day changes starts halfway through the morning but I've got used to it". Then my last Omega job also went wacky due to too much vertical play on the Day disc location. Had a good search for Omega Technical advice information - no doubt it's around but nothing found. The task is to align the date change to work at the same time that the Day change starts. Trial and error will get you there but it's a pain. Make sure you check before re-assembly - it's really fun when it's a one piece case. Yes - been there.... So the photo's below show how the set up should look. Note the spring steel hook is about to hit the date ring teeth - the day change wheel pointer is flying about 035 degrees. Should get you sorted. -
Not sure of level of expertise at rwg.bz forum, yet every bit of info might help. https://www.rwg.bz/
Out of curiosity seeing as how I do not trust artificial intelligence for variety of reasons. First eBay and then generic ones. But it would seem odd that you would make a generic screw blue if they were blue in the first place? https://www.ebay.com/itm/235878965719 https://www.jewelerssupplies.com/blue-screw-for-date-indicator-generic-for-rlx-3135-R3135.5600.html Here's a video when he takes the dial off some of the screws definitely look blue?
