Bergeon 30207 How To Use?
bobm12
I'm thinking about buying this tool:
It is said it helps work on balances plus a lot of other uses. Can you guys illustrate/explain those different uses and if possible with support of pictures.
Much appreciated and thanks in advance,
Cheers,
Bob
I have looked at this tool many times. The idea is to secure hairspring stud while pinning a new hairspring to it I think.
However I think it would be very handy when manipulating a hairspring. The cost as always put me off
This tool might do the same job on the bay item number 311482941796
A strange tool to find pictures of because it goes by multiple of names. Plus to make things more interesting hairspring can also go by balance spring. Then for such an interesting tool not finding a lot of references to it?
http://www.geocities.ws/dushang2000/Balance%20Tools.html#Balance%20Spring%20Stud%20Table
Nice link John very informative
What's interesting is missing tools for removing the balance staff plus his staff grinding tool extremely expensive and if you're not careful bad things happen. Specifically if you're not careful you grind more than the staff and you make a nice hollow into the balance arm. Then if you are grinding out it's always good if you would measure which are grinding out just to make sure that whatever you replace with exactly matches.
Then as pointed out Missing is the Platax tool I've attached photos of something else that's missing.
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
