So.
I finally managed to plonk a gold skeleton-version of the venerable and beginner-friendly 6497 into a black case.
However, given there's no actual dial to hold the hour-wheel in place, it gets dislodged and hour indication is thus random.
The 'dial' is a DIY 3D-printed thing, painted red to go with the gold and black.
Any ideas on how to retain the hour-wheel without obscuring view to the fairly ok looking movement?
I don't think it is the ideal method (as opposed to adding some cover to the main plate that retains the hour wheel) but I believe it's possible to put a small dial washer on over the hour hand, then place the minute hand above the washer to push down on the top of the hour wheel hole. The washer would only be big enough to pass over the end of the cannon pinion and be obscured by the base of the minute hand.
Looking at a few listings for skeletonized 6497s on eBay, many of them have a small washer pictured beside the hour wheel and I assume that's it's purpose.
The curved washer you refer to is definitely designed to go directly onto the hour wheel - i have it here and it fits nicely under the dial face - which isn't there...
However, your idea with a thin washer under the minute hand is great. Only, I have no such washers available. Oh well - 3D-print, an assortment of tiny drills and a bit of patience  had me making my own.
And it worked. The watch now keeps time as intended and has approximately the look I was aiming for.
3D-printed washers & fitting drills:
Washer fitted under minute hand, holding hour wheel down:
Result:
@mbwatch Thank you for pushing me in the right direction 🙂
Edited by MartinF
Wow great solution! Impressive you were able to accurately print something so small. Sounds like your movement only had the normal large dial washer. The movements I saw included a far smaller washer that couldn't have been more than 2mm in diameter.
3D-printing has saved my behind on so many occasions. As long at whatever doodad I need won't require loadbearing capabilities, it's often quicker to make one up than locate it on Aliexpress and wait for the mailman to deliver. Try have a look on www.thingiverse.com...
Detail level on resin-printing is insane. A cheap chinese 299USD printer will deliver stuff like this 43mm long Honda Blackbird motorbike model, complete with ittybitty brake rotors, handles and grabrail.
I'm now looking for an assortment of watch-sized screws, washers and other tiny bits needed for this hobby. Where do you all source stuff like that?
55 minutes ago, rehajm said:
a few more plastic parts and you’ll have yourself a nice Seiko!
Print a pallet fork & escape wheel and you've got a Tissot!
  • Haha 2
  • Similar Content
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
    • Could you fit a sapphire crystal? My 'daily wearer' Breitling Aerospace is 22 years old and there isn't a mark on the sapphire crystal.
    • Oh that's neat. I typically use a thin strap of rodico laid over the pallet fork to affix it to the upper plate but it can be hard to retrieve sometimes. And as I did more research, I may have just found your own earlier explanation: https://learntimeonline.com/forums/topic/potence-clip-for-full-plate-p-ws/
