Ok, my current problem is the watch slows down unless I set the watch, which turns the cannon pinion which turns the minute and hour wheel: using a bench key. Is my problem friction with the minute and hour wheel. I do have the dial on with the dial washer.
been a while since on this blog:)
Please Help. Need Old Hippy Advice
Ladies Waltham Size 0, 7 Jewel.
7 hours ago, jdrichard said:
using a bench key
It would've been nice if we had a picture of the exact watch. On the other hand You gave us a clue bench key. Typically in situations where people are using a bench key when the watch is out of the case the watch will go into setting mode. This is because the case has a sleeve which holds the stem in either winding or setting mode. When the watches out of the case it goes to into the setting mode. The problem with being in the setting mode out of the case is as you found out the watch doesn't have enough power to power all the setting mechanism. But some watches do have a method of putting them bac.
k in the winding mode out of the case we would need to see the exact picture of this watch to see if it has that. Otherwise the only other solution is to put it back in the case
It would really help if you gave us a picture but it did give us a clue. If this was basically a really tiny little pocket watch then typically when the pocket watches out of the case the watch goes into setting. Running a watch in setting mode would have a similar effect to what you have in other words you're trying to drive the entire setting mechanism. Some pocket watches had a way of putting it back in running mode out of the case otherwise try putting it in the case and seeing if that solves your problem.
 With low wind, and stem in set position, slowly turn the hands anticlock , if this stops the watch or reduces amplitude ( sometimes the watch runs backward ) the problem is with the  parts you mentioned or locating pins belonging thereto or the minute train bridge if there is one ( anywhere accross the entire minute train  ) and if so, then turning clockwise would enhance the oscillation.
 Crown pinion remains engaged with winding wheel, when stem is in wind position, so a fault thereon can also introduce friction into the rate, there you have crown pinion, winding wheel ,,,,etc.  for instance there is a jewel and pivot embeded under the crown wheel, the pivot can rub underneath the crown wheel,  affecting the power in gear train.
As John says , helps to know what movement your talking about.
Edited by Nucejoe
spelling
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
