Good evening watch friends, I have serviced a Certina (blue ribbon) 25-651 automatic movement. After service the watch runs very nice, but winding by hand is very heavy. What can cause this problem. Thank you all in advance for any suggestions. With kind regards, Hans
At what point does the winding become stiff, crunchy, resistant, etc? Does it feel like this when there is no power in the movement, or after you get to half way would, full wind? How doe the mainspring feel when it slips on the barrel wall? What breaking grease did you use? Did you try what it was like to wind before the automatic module was fitted? When you fitted the keyless work, did you observe the winding pinion, clutch and yoke? Was there any sloppy movement of those parts, especially the winding pinion that may have worn a larger slot, therefore it finds it hard to engage with the crown wheel because of the movement and it feels tight and crunchy, or close to fu7ll wind the clutch slips against the winding pinion because of the slop or an underpowered yoke spring. There are many thing that could be problematic. It's best to give us some pics and a more detailed background to the movement. what was it like before it was serviced, etc?
Strangely enough, this topic was covered in the lesson when assembling the Valjoux/ETA 7750 on Monday night.
Hello, thanks for the response. I used Moebius 8217 for the barrel wall and Lubeta for the reverse wheels. The winding pinion and clutch where oké. I re-used the mainspring because it looked oké to. After three or four days in the watchwinder the watch runs nice.
I'll try the winding without the automatic module.
  • 8 months later...
I'm just curious (as I have V105). Would you oil just one of the protrusions or all of them? I think I see three protrusions in the picture.
I would just oil two of them opposite from each other, but that's just what I do. Some might do more.
On a side note I use V105 for rotor bearings as well and don't buy into using V106. Just more money for pretty much the same stuff.
If you don't have V105 for the bearing, a small drop of 9010 on just one of the ball bearings, unless they're ceramic bearings that don't need to get lubricated at all
This is the first time I’ve heard of that. Do you remove the rotor bearing or do you apply V105 directly to it? Because we don’t want to get V105 on the rotor itself, right!?
As pointed out above, it's usually the reverser wheels. I've had this problem, and re-cleaning the wheels has fixed it.  Or they could just be too worn
If it is a bolt type rotor bearing like in a modern ETA 7750 I would remove the bearing and dip it in. If it is a friction fit type, like on an old Valjoux 7750 then I use a pipette to put a very small drop on the bearing without getting on the rotor, because it will leave a bit of a waxy white mark otherwise. Try it, works a treat!
If a client brings in an automatic that hasn't been service in 8 or 9 years plus, I replace the reversing wheel(s) as standard
That's a sensible policy, if the wheels are available, but they are becoming hard/impossible to find.
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
