Bulova Accutron Astronaut.....
Hi All .
  Well I finally got an Astronaut !!  I had been searching for a while , and bidding once in a while , but just missing on closing the deal at the last seconds a couple of times . I had this one in my Ebay watch-list and decided to pay a little more for one that had just been serviced by a watchmaker that specializes in accutrons , in New York . I made an offer that the seller accepted . The seller lives in Virginia .
When I got the watch I could not set the hands so I contacted the seller . He in turn contacted the watchmaker who said he guarantees his work , so send it to him and he would take care of the problem . The seller paid for the postage and $500 insurance to New York and the watchmaker paid for the postage to get the watch back to me .
  It was delivered today and runs great . I had a new crystal waiting for it and I Installed it this evening .... I'm stoked .
The attachments are the sellers pics ....... The watchmaker installed an Accucell 1.35 volt battery , which is the original operating voltage for the Accutrons .
  The actual watch with new crystal and the watchband look much better than the pics .
Howzit ramrod , Happy Holidays to you and all the members .
I really do like and wear my Astronaut .  Since I bought it I have installed a new crystal and changed out the watch band to a coffin link bracelet that I had on a vintage Seiko DX . I swapped the deployment clasps also .
Believe me when I say that I would not dissuade you or anyone from getting a watch that they had their sights on . ...But as far as the Accutrons go , they ARE a different breed . If you decide to get one I suggest that you read up on them first , get one that is running , and know that they are not as easy to work on as say ,  a mechanical watch or even a Quartz . If you need to get one serviced there are sites [even advertised on Ebay ] , that do a flat rate service for a little under $200 .
  I am still learning to service them , starting with the 218 model . I have bought and am still buying watches , movements , and parts ,  running and not , the tools and meters to service them , the tech manuals ,  and even a new stereo microscope with a camera port and camera so I can see them on my monitor .
  So far I have about 10 complete working watches , and 2 or 3 works in progress . I even have a Citizen Hisonic which is the same tuning fork movement .
  FYI , there is also a Bulova Astronaut Limited Edition with a Swiss ETA automatic movement . That one is on my wish list . It has a crystal presentation back and is signed by the Astronaut Buzz Aldrin .  A little pricy , but very nice .
I hope I shed a little light about these beautiful Accutron movements....
Edited by ricardopalamino
very nice stuff, RP. the buzz aldrin watch has got to be a grail for you.
this is probably something i should back off of only because i don't have the proper tools and diagnostic equipment to do them justice. if i ended up with one, it would probably end up sitting for years until i got over my mechanical watch obsession.
you're on the right track with all of the tools that you purchased to fix these things.
