My Watch Projects
RCDesign
I’m a total noob when it comes to making cases but I have been able to put together these two watches so far!
The fist one is made from Dural aluminum using my small CNC-machine and the second one is stainless steel made using an old Deckel mill from the 40’s.
Dial and inserts are made of anodized aluminum which has been engraved and then filled with a mixture of paint and lume.
First try:
The raw material a milled piece of Dural
Ready to go in the small CNC-mill
Stage one - done!
The back "milled out" and now it looks more like a case
Ready to lapp angles etc
Making the dial
Dial with lume dots
The result
Second try:
The raw piece of stainless steel
Milled and ready for the Deckel
143856176407073000_resized.jpg?width=120
The machine
143871222360948100_resized.jpg?width=120
The form of the case in scale 3:1
After MANY runs, the depth is correct!
Starting to look the part!
Drilled lugs
Lugs getting "plugged"
.....getting there
The sides lapped to 3 degrees and the holes are "gone"
Routing a bezel
Getting painted/lumed
Making the caseback (press fit)
......and the result
Truly excellent work RCD, the first one is great, but I just love your second one. Very handy tool the pantograph mill.
You're getting excellent results making the dials. What engraving machine are you using for the dial? I'm also curious to know what movements you are using?
I'm using a Roland PNC-2300A
I'm limited to 0.1mm wide traces using rotating endmills but have plans to try dragengraving using diamond bits.
Building a small pad printer is next on my list! :)
Miyota quartz movement in the fist one and a Tissot 782 in the stainless version!
That's a fine piece of kit you have. A friend of mine used to do engraving as a home based business many years ago, I can't remember the make though.
Keep up the good work, and don't forget to keep us posted, we like seeing this kind of thing. :)
    • As Richard said, this is a really old school trick for joinery.  Cut i strip of paper, might need to be watch paper  around 1 " x 1/2" lay it over a staking block then press the stud screw into and through the edge of the paper upto the head of the screw. You probably wont even need to pull the paper away the head will pull itself through.
    • Thanks Jon, my mum is getting there day by day, so strong and determined, they dont make em like this anymore 🙂 Old folk are so amazing,  my mum used to love her golf, she didn't stop playing until she was 70 . Enjoy your trip and your golf.
    • Hello,  i am looking to source a winding stem (winding arbor) for a waltham 6/0 d movement. I have found some that claim to fit 6/0, 6/0s, 6/0b etc and somealso claim they will also fit the d as well. The d does have hacking which is driven by the stem seating completely. Given some of the costs of these, i was hoping someone would know of any interchangeability with a source, or know a source where a confirmed 6/0 d stem can be had. I am in the US so a US dealer is best.    thanks in advance.
    • So great to see and hear- your mum looks great! …my mil had a stroke last summer in the golf course parking lot. I’m flying out tomorrow to visit and play golf. she’s ornery because she can’t get off the tee but I hear she makes up for it on the greens since she’s been putting since a week after her stroke 🧐…
    • Very best wishes to you and your family, as a carer myself I know how difficult things can be.
