D. I. Y. Watch Timing Machine.
What does the boss look like where the screw is and the alarm bolt yoke fits over. Is everything flat including the setting lever and yoke spring. Also something doesn't look right with that yoke spring.
Yes, a rather strong smell of ammonia if you get closer than half a meter. It very much depends on the quality of the ultrasonic machine. Then again, some people who have invested in an ELMA US, report outstanding results. I don't know what to think. If I can get a used Elma for a decent price, I might want to give it another try. Anyway, I'll keep my fingers crossed that your US will do a good job! 🤞
Thank you Mike for the hints! I did go to HS Walsh and buy few tools that will help me start 🙂 I also went to the Royal Observatory at Greenwich, I saw the collection and it is amazing!! Harrison H4 is indeed an amazing manufact, and the story behind it (about the prize from the government) is incredible. Again, thank you for your suggestions, you made my day!
Is it the correct screw? -
By TimepieceTinkerer · Posted
Hello watch enthusiasts, I'm encountering a peculiar issue with my Seiko 4006 movement and could use some advice. Specifically, the alarm bolt yoke doesn't function properly when I tighten the screw on the calendar plate directly above it. This results in the alarm not functioning as it should. However, when I leave the screw loose, everything works perfectly and alarm bolt yoke is functional as should be. I've tried replacing the alarm bolt yoke, the alarm bolt yoke spring, and even the calendar plate itself, but unfortunately, none of these changes have made a difference. The only workaround I've found is to keep the screw on top of the alarm bolt yoke loose. Has anyone else experienced a similar issue or have any insights on what might be causing this? I'll also be sharing pictures to help illustrate the problem. Looking forward to your suggestions and advice! TT
