First movement = First broken movement
By Deebee2024 · Posted
Hi This is the watch I was talking about in my introduction post. It was my Great Granny's watch and I'm going to clean the watch and then find a new winder to replace the missing one. My problem is I cannot get the movement out. I managed to remove the back but I'm now stuck. How do I remove the movement ? There is a broken screw where the head came off when I tried to unscrew it. The winder is missing and there is a lot of rust. I have some Isopropyl to clean it. I have a watch a little repair kit. What should I use to remove the rust? I can see where to remove the strap so I should be able to do that to clean it. -
Is this £ 220 for a new Pearl cleaner? -
I see thank you. Would you say £220 is worthwhile for a machine? Naturally, if I went with the National Electric, it would be cheaper.
What a disgusting act they did, i would have been furious. -
By trenchwatchww1 · Posted
The last photo is the dial it had
