Accutron 218 transistors
I think it should be the other way round, thanks to you. -
You have been a great help to me on many occasions. Thank you for the offer…
By Hawaiikook808 · Posted
Another Question. Does this reamer look like it fits the reamer plunger? This one and all the others feel like they should push in all the way. Are they made like that so they don't turn or move when reaming a hole? Thanks. Frank -
Yes, it "should", but there was no way to get the springs out of my cal 627 without bending them. The ends were too big for the slots in the chaton. Whether they left the factory like that, or someone fitted new springs ..... 🥴
