I joined the forum after reading for quite some time. I started servicing and repairing my watches since 2 years, after my initial hobby if servicing and repairing my antique French wall clocks. Watches are less bulky to collect (a few clocks per room just the from looking like a museum) and more fun, too. I am into vintage wrist watches Swiss, Seiko and Soviet dress style watches and into Jaeger Lecoultre small table clocks. In the meantime i picked up some knowledge and skill that I feel free to share.
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
Clocks are my thing mostly from 1900 backwards.
    • I suppose? If it worked before and it doesn't work now I guess the question would be why does it not work now? That would come back to if you did not have the chronograph module on will it work or is the chronograph module sucking too much power out of the watch basically 99 usually when they go bad you can hold on the tube part and usually just spin the wheel because it has zero holding at all so usually when they go bad they go bad very bad. You should build hotel when you set the watch as to whether it seems to have any friction or not. I'm just wondering if the chronograph module is the problem.
