Click spring replacement
Pieter
How do you replace the right click spring in a Smith’s Enfield railway clock? How do you attach it to the front plate? With a rivet and a hammer or bolt? Not much room behind the plate for there is the clock spring. Any video link?
13 hours ago, Pieter said:
I drilled the rivet out. How does the screw get enough grip? The plate is very thin….
The click spring should have a tiny notch that fits into a small hole in the plate. Just a tight screw down will be fine or to be safe a spring washer. (If room)
Hi Pieter, I have purchased these rivets from a company called Accu - heres a link https://www.accu.co.uk/ the rivet I used  is 2mm x 6mm Button Head Solid Rivets (DIN 660) - Stainless Steel (A2)
You can buy the springs from lots of sellers online but I have found some sizes are very hard to come by. They are either Left or Right and the critical thing is the distance between the screw hole and the tag that engages with the hole in the plate. I ended up buying a straight spring and bending it to the required size.  I bought mine from this seller on eBay
eBay - Advanced Search - Shops - Find Shops - Lisa's Pet and Home Store
I can understand why you would prefer to use a rivet but to be honest I found it impossible to splay the rivet enough without breaking the spring, so I gave up and used a self tapping screw which has worked really well.
Good luck !
Edited by Michael20
Good luck !
Thank you for the advise. The frontplate is so thin so i am wondering if a self tapping screw will hold but i will give it a try. Do you know by the way hiw to adjust the hour hand on the fusee clock? Is is a little bit off so i like to adjust it.
Normally the hour hand on a fusee clock is friction tight. When you have the minute hand pinned on hold the minute hand near the center then try to move the hour hand by holding it as near to the center and move it to the place you need it to be. Always move hands from the center this prevents bending the hand and breaking off.
    • Er yeah, not quite sure how to respond to that one Mark 😅. But yes i fully appreciate what you have done here today. I look at it like this, i dont know if you have children Mark,  i have a son and a daughter both around 30 years old but still my babies. I remind them every couple of months, " if something happens to me, i get run over by a bus, i have a heart attack while out running, I eat a very dodgy burger, you know where the spare hidden house keys are dont you, you know where the stashes of money are don't you, you know the things i have that are valuable don't you, you know how to deal with my finances don't you, you know the value of my watchroom and where the value lists of all the tools and watch collections i have are dont you, dont mess it up and dont get ripped off i want you to be rich when I'm gone "  This forum is your baby Mark, i dont think i need to say any more. Appreciate your time Mark, live long and prosper matey 🖖
    • Thanks Richard - Send me a PM - we shall discuss and get you set up 👍
    • It's a good point, we really love the forum and are scared of losing it. @Mark do you mind if we exchange contact details?  What happens if you don't wake up in the morning? Hopefully not but @Neverenoughwatches is correct, who knows. Could the site be passed on to someone else? It would be a  travesty to loose contact with each other and also so much information.  Please note, the question arised because we care so much.  We wish that you will live for ever but none of us will.  Beat me too it.
    • As long as it’s legal and not spamming, information shared in private messaging between two consenting members is no concern of mine matey 👍 this isn’t eBay 🤣
