Click spring replacement
Pieter
How do you replace the right click spring in a Smith’s Enfield railway clock? How do you attach it to the front plate? With a rivet and a hammer or bolt? Not much room behind the plate for there is the clock spring. Any video link?
13 hours ago, Pieter said:
I drilled the rivet out. How does the screw get enough grip? The plate is very thin….
The click spring should have a tiny notch that fits into a small hole in the plate. Just a tight screw down will be fine or to be safe a spring washer. (If room)
Hi Pieter, I have purchased these rivets from a company called Accu - heres a link https://www.accu.co.uk/ the rivet I used  is 2mm x 6mm Button Head Solid Rivets (DIN 660) - Stainless Steel (A2)
You can buy the springs from lots of sellers online but I have found some sizes are very hard to come by. They are either Left or Right and the critical thing is the distance between the screw hole and the tag that engages with the hole in the plate. I ended up buying a straight spring and bending it to the required size.  I bought mine from this seller on eBay
eBay - Advanced Search - Shops - Find Shops - Lisa's Pet and Home Store
I can understand why you would prefer to use a rivet but to be honest I found it impossible to splay the rivet enough without breaking the spring, so I gave up and used a self tapping screw which has worked really well.
Good luck !
Edited by Michael20
Good luck !
Thank you for the advise. The frontplate is so thin so i am wondering if a self tapping screw will hold but i will give it a try. Do you know by the way hiw to adjust the hour hand on the fusee clock? Is is a little bit off so i like to adjust it.
Normally the hour hand on a fusee clock is friction tight. When you have the minute hand pinned on hold the minute hand near the center then try to move the hour hand by holding it as near to the center and move it to the place you need it to be. Always move hands from the center this prevents bending the hand and breaking off.
    • I for one would have to pass, I'm not joining Facebook.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  This might be helpful for you.  704789946_TZIllustratedGlossary(2).pdf
    • I take it that you're comment re the Unicorn is 'tongue-in-cheek'? Would any of the watches that are on the link I posted be likely to be radium watches? What period was that prevalent in and when did the practice stop?
    • As much as I hate Facebook, can a forum-like place be set up on there? Free and the ownership can be taken over by the next person whenever.
    • I existed before the term mechatronics engineer existed. I had to combine electricity, electronics, pneumatics, hydraulics and computing just to keep my own equipment working. I have never sub contracted any of my own repairs to the suppliers because I know I could do a better job. For a long time, dental suppliers in my country would bring their dead equipment to me that their own engineers cannot handle. I have accidentally embarrassed a couple of hospital heads of engineering by demonstrating their inadequacy.  I think mechatronics is the most under-appreciated, under valued of all the engineering sciences. I had a part-time dental assistant about 25 years ago, who was studying mechatronics in the polytechnic. She was absolutely clueless about the job prospects for a mechatronics engineer. I asked her about her aspirations and she replied that she really wanted to work in the games industry.  In our dental profession, equipment have evolved from simple mechanical to electro-mechanical to logic-driven electro-mechanical and currently to computer driven machines.  The medical equipment suppliers who employ mechanical engineers and/or mechanical engineers cannot cope with the repairs of the newer equipment. And many times end up changing whole modules and whole machines just because they cannot repair them. But I think HR is afraid to employ a mechatronics engineer just because they don't know what a mechatronics engineer does. Mechatronics is much more fun. It combines almost all of the engineering sciences and produces an all-rounded engineer. But until HR changes their mindset, not all door will be open.
