Dumb newbie question
I have just completed my second attempt at lubricating a watch movement. One of my biggest challenges is lubricating the pallet jewel since , as I lower the oiler towards the jewel, I can only see in 2D with my loupe. As a result I sometimes end up hitting the top of the jewel or reaching below it.
Is there a trick to this or does it just get better/easier with experience?  I know microscopes are 3D but not in the budget right now. Do you just have to sort of feel around when using a loupe?
What magnification loupe are you using mark
 I oil the escape teeth with smallest bit of oil, let the watch run for few hours then add more oil, repeat as long as you gain amplitude.
Some folks oil the pallets before installing it, instal and  let the watch run for couple of hours, remove & rinse the fork, reinstall.
There are threads on WRT that show images of oiling.
Edited by Nucejoe
Angle your movement so you can see the impulse face of the pallet stone like this video shows
You might find it easier if you hone down the end of your oiler and put a slight bend on it. I find this helps when oiling pallets.
This is one of the best YouTube videos on this subject, which will definitely help. It is all about practice. Don't expect to get it right the first few times.
I've just had a class of students in today and they were oiling the train wheels jewels for the very first time using stereo microscopes and by the time they got to the dial side and the very last ones they were getting the lubricant in the jewel without painting the top of the oil-sinks. Lubricating pallets is not the easiest thing to do, especially without a stereo microscope. The more you practice, the more you'll get it bang on.
    • Hmmm you know when i said some damp might have caused the bubble originally hmmm 🤨
    • Are you all jerking my chain, I'm a yorkshireman £4.04 is too much 😆
    • [Myota2034] Custom simple quartz watch — PricewaterhouseCoopers On a very very different note, here is a watch from approximately 2000 when I was a Partner with PwC, Management Consulting. It was a simple “marketing watch” with a clever “vase of knowledge” that is subtly revealed on the dial as the second hand progresses. Clever for a simple watch!⌚️
    • I think someone else has though. Some where here using a modified perspex sheet. I may be wrong i may be right , i think it involved fitting the arbor to a pin vice. I dont have experience of the bergeon winders, are the handles not interchangeable ?
    • Never tried dial dots, i always considered them as a bit of a bodge.  You are adding something that was never intended to be there. I wonder how the adhesive reacts to any part of the movement, hot summer heat and i think things might turn sticky. Most adhesive backed stuff has a tendency to soften and slide around so it may spread, i have used a lot of so called sticks all adhesives in my industry that are just not up to the job. I suppose they get you out of a problem quickly, but how permanently might that be ? I would just explain to the owner that it may or may not work. WWs other ideas are a much more permanent solution but both have their risks . I've tried milling and dial feet replacements, hmm it was ok, ive heard of folk dimpling the face , so that needs care . And i have soldered a few times , all with good results but i am very careful and I practiced it a lot.
