Hello all,
I'm a hobby horologist and have just gotten hold of a Seamaster with a 1342 in it....not working.....(sound familiar?)....a new battery didnt change things...just made thecsecond hand to mobe a little then stop. so I'm here joined to see if I can get any info as to how to move forward....any hints or tips would be gratefully received...
If you had a Witchi Cyclonic you could possibly spin the train and free it up but sounds like it could use a cleaning/service.....you did say it ran for a few seconds....
Hi a line release tool (available on eBay or the cheap £30 alalyser). Will spin  up the watch and clear a jam or sticky oil. First put a drop ofnaptha ( lighter fuel) on the pivots then tun up the watch, re fit new battery if it runs you know the movement is ok but it will require servicing. If still dead check circuit for pulses and the coil resistance and for being open. Circuit.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
