Hi everyone,
I wondered what your suggestions would be for someone starting out in the hobby.
When you haven't got mainspring winders yet do you best:
  • Just leave it in the barrel and assemble everything after cleaning the rest
  • Take it out, measure it and buy a new one (don't know if that's feasible for older watches)
  • Take it out, measure it and get an appropriate mainspring winder
  • Something else....
Thanks for the advice!
You could just buy a couple of the most common sizes. Best Chinese sets are allegedly good. Manual mainsprings are easy to wind by hand but automatic springs are trickier because of the bridle in the end. Buying new springs is also an option.
23 minutes ago, LuigiMeister2800 said:
Hi everyone,
Watch the YouTube videos in how to hand wind.
It was 15 month before I obtained a set of winders. Only used them unsuccessfully since.
Hi Maloccio has given the options, I still do it by hand, but if you are not sure just buy the winder to suit you purpose at the time. That way over time you will build a collection of the ones you use the most and. Not some ornaments which never get used.
1 hour ago, LuigiMeister2800 said:
Hi everyone,
All depends what you are working on. If the right mainspring is available and the money to buy one each time isn't an issue then a new one would be the best option. Downside is you dont get to aquire the skill of winding mainsprings. Which eventually if you work on a lot of old watches you will need.
Yey old timer, my hero 👍
Hi everyone,
In my eyes leaving it in the barrel isn't an option, when I started i thought about it and i tried it. I soniced the barrel upside down in the hope it would clean it, it did but not to an acceptable level at all. No way are between the coils gonna get clean or all of the bottom of the barrel. You have to bite the bullet and just get stuck in, have it out and hand wind it back in if there's no option of a winder. Practice ,practice and practice and when you're done practicing......... you've guessed it , practice some more.
I think you should acquire some mainspring winders, you use/need them in the future, hand winding is a last resort for what ever reason, too much distortion especially from beginners, I think sometimes it is better to hand clean with arbor out and reassemble than hand wind, but I have winders so just my opinion.....new is a great option like Neverenough said...
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
