How to remove the balance spring
Have a look here, quite a good video about cleaning without a machine Tom
Thank you very much for being extremely helpful and patient. I know a guy who can 3dprint, I can design a spacer I guess. For cleaning with the lighter fluid, is it entirely done by hand, or do I need a jig (spinner?). Any informative links appreciated! Would you have any suggestions for the app? I'll test it on my Slava.
I did wonder about the feasibility of mixing two oils. I am guessing that 9010 / 9020 or HP500 / HP1300 would be a better mix than 9010 / HPxx. Some people might think that was heresy but I guess the only consequence is that you might have to service the movement again if you got a poor result.
By LittleWatchShop · Posted
Yes, however, as you are just starting out, you can progress using Ronsonol lighter fluid (or equiv) to clean. Use pegwood to clean all pivot bearings. Yes. Some disagree with me. I have many hundreds of dollars invested in multiple time graphers and vintage timing machines. The phone app is just fine for a beginner. Probably just needs a good cleaning. My SWAG, is slim to none unless you own a 3D printer and can design and print a spacer Here is a re-cased Mickey Mouse watch I made using 3D printer...lol!!
