Accutron 2210
Although I was trying to be good and not purchase anything till I had sorted out the multitude of watches I have in the queue, I saw this Accutron on the bay and bought it for £32.49 plus about $5 postage to my sons place in LA.
I had not got an Accutron 2210 up to this point in time, and to be honest the movement does not have a particularly good rep for reliability.  However, the parts are comparitively cheap compared to the 214 and 218 and through a quirk of fate I have quite a few NOS 2210 parts that were amongst a job lot of 214 and 218 bits I bought some time ago.
It is a 1973 movement and coincidentally that is when these were first produced and the movement is quite small, being used in lots of ladies watches which do not command the same prices as the mens accutrons - good for getting parts.  I queried with the vendor the size and was advised it is 34mm excluding the crown so it is in a mans case.
Condition was described as "Awesome" but I will settle for reasonably good seeing it is over 40 years old, there are some scratches on the glass and I deduce from the back that the case is gold plated which is difficult to tell from the photos, but I will take what comes.
It will be a while until it is sent over to me along with some 218 coils I took a punt on but I look forward to seeing it.
Was not going to buy any more repair jobs but I weakened, however, I am definitely back on the wagon for a while.
Cheers,
Vic
Got the watch and the condition is indeed good. It's a nice steel case.
Took out the battery and it is dead so I have sent off for a couple of Renatas. I have a compatible one but it is off one of those sheets of batteries you get for a pound and I resisted the urge to try it out. Hopefully in a couple of days time the new ones will be here and who knows.
Cheers,
Vic
And some you win !
The engine room is fully functional George with a new battery inserted and would you believe the pointers are moving as well.
There is a slight blemish to the left of the tuning fork insignia but I have decided to leave it alone for now and just check the accuracy is ok. The Vendor has put a new brown seiko calfskin strap on it which, though not quite right for the SS watch will also do for now.
So I have a fully functional Accutron 2210 - total cost £38.00 which will do for me - question is - will I ever sell it on (wife laughs in the background) - OK probably not.
Cheers,
Vic
Just an addendum.  On the original photo above it looks like there are black dots on the pointers, in fact there are no black dots anywhere, it must have been mucky when they took the photo - bonus.
Could one of the inimitable moderators put an "i" in pointers above - a small thing I know but it irritates me :cool:
Cheers,
Vic
Done!
If your like me, probably not.
    • Hi I got a Jaeger LeCoultre K911 movement, where one of the stems was broken. Part no. Should be 401.  Im based in Europe and tried Cousins but its discontinued there and cant find it on Google. Is there a way out to join the ends? Or an alternative movement to source parts from?
    • The part was how it fell out of the movement - the train wheel bridge wasn’t screwed in.    I’ll probably dismantle the part, if I can, to work it out.    The train of wheels ran fine - it was only once the keyless works were installed I noticed the problem.
    • Hello, I am about 5 months into watchmaking and I love it!   The attention to precise detail is what really attracts me to it. (and the tools!) I am working on a 16 jewel 43mm pocket watch movement.   There are no markings besides a serial number (122248) .  The balance staff needs replacement. The roller side pivot broke off.  I successfully removed the hairspring using Bergeon 5430's.  I successfully removed the roller using Bergeon 2810.   Did i mention I love the tools?! I removed the staff from the balance wheel using a vintage K&D staff removal tool  with my Bergeon 15285 (that's the one that comes with a micrometer adjustment so it can be used as a jewel press as well as a traditional staking tool...it's sooooo cool...sorry..  can you tell i love the tools?) No more digressing..  I measured the damaged staff in all the relevant areas but I have to estimate on some because one of the pivots is missing. A = Full length  A= 4.80mm  (that's without the one pivot...if you assume that the missing pivot is the same length as the other pivot (I'm sure it's not)  then A = 5.12 mm...(can I assume 5.00mm here?) F=  Hair spring collet seat  F=  .89mm   (safe to assume .90 here? .. I am sure that my measurement's would at least contain  .01 mm error ?) G = balance wheel seat  G = 1.23 mm  (1.20mm?) H  =  roller staff  H =  .59mm  (.60 mm?) B  = bottom of the wheel to roller pivot   B  = 2.97mm  (3.00 mm?)     here I am estimating  again because this pivot is missing. So my friends, and I thank you profusely,  can you point me in the right direction as to how to proceed? Do i buy individual staffs?  or an assortment?   Since I don't know exactly the name of the manufacturer, will that be a fatal hindrance?   Tbh, I'm not even sure what country of origin this movement is. Thank you!
    • Thats why i asked that question earlier, what happens if lubrication is placed directly on top of epilame ?  As opposed to walled within its non epilamed area . I'm not saying its right, i have no idea , just asking questions.
    • thinking of where epilam should be removed did you know there was a patent that covers this? At least for the escapement I'm attaching it. GB1057607A-1 epilame.pdf
