Cartier repair
hel
Hello lovely people
I have this watch, I can't find any info and I am yet to take the back off.
I know zilch about watches but got this at a second hand store.
It is beaten up.
What are the chances of it being real or will you tell me I am dreaming 😆
Would appreciate any info you are willing and able to give.
Thankyou
Helen
12 hours ago, hel said:
Hello lovely people
It is beaten up.
Thankyou
Helen
Its just wrong, all wrong. Even if it were right it would still be wrong. Time to wake up sorry, this would have probably been in a vermeil case if it were genuine.  The Cartier brand is well known to be have been extensively faked over the years . A peek inside may well reveal its Far Eastern origin .
Haha thankyou so much. I will attempt to look inside and maybe get a pic.
6 hours ago, RichardHarris123 said:
I think fake. Even if not, it looks badly corroded and with the crown and stem missing, probably corroded inside.  Take the back off, let's have a look.
So the back is proving very difficult to remove. Any tips?
Ok, I'm almost too embarrassed to post this pic 🤣
So after much struggling I got the back off to reveal this 😂😂
It says
Unadjusted
Myota Co
Japan
Thanks so much for the replies.
The band might clean up well 😆
Much appreciated
It says
Unadjusted
Myota Co
Japan
Much appreciated
Holy crud Batman, I'd say that battery is toast, i mean it actually looks like a piece of  burnt toast 🔥 or a muffin even, i would have to butter it first before i put it in the bin . I've seen worse inside a watch, i cant remember when or where I've seen worse but i probably have or maybe not. OH's suggestion to bin it is too good for it, i think i must make a watch crush for watches like this.  Keep looking Helen, one day it will happen, I'll try not to be so harsh next time, i applaud  your bravery to show us though, many dont even reply.
If it is a fake they faked a Must and not a Cartier😂?
You may have been innit just for the treasure hunting but If you like the idea of improving this tis true you could replace the movement without much expense and cleanup the case and band. The dial is in good shape…
I have no suggestions on the..bezel thing? What is that? Could that have been plated or painted at one time? Ugh…sorry, now I vote bin…
Haha when you know you know and yes mate tis true you know 🤣 . Poor Helen all this jibe, we are sorry H we are quite naughty today please forgive us.
  • Haha 2
Far be it for me to discourage a little treasure hunting. Last year paid a couple hundred gbp for an auction lot for ‘costume jewelry’ and a couple watches, one clearly a Bell & Ross or Bell & Ross fake. The wife wanted the baubles so I paid more than I should…though those pearls in there do look real, don’t they? Well the pearls are real- 3k worth and I have a lovely Bell & Ross fake with a Chinese movement that puts the timekeeping on my iPhone to shame 🤪. Happy hunting…
3 minutes ago, watchweasol said:
Hi. A good dose of elbow grease and a new movement  approx £10. To £12  and you have a decent time piece  might not be the real thing but brought back to life, worth a bash in my opinion. Go for it.
Just the sense of achievement and lessons learnt can be more than worth it. I'm battling at the moment with an old cylinder esc. movement that is worthless. Trying to make a new plug for the cylinder or slowly but surely file in a new pivot on the old one. In the process I've learnt that turning a balance staff is a real skill but not beyond my ability. All lessons learn are worth the effort.
Thanks everyone for your input!
Quite the funny banter here 🤣
I did consider a new movement and clean up attempt but it had an inlay around the face that was broken so alas it has gone to watch heaven.
Appreciate all the responses from the actual watch worthy 👌 😁
That big find is just around the corner H , just keep believing.
    • When can you use a standard crystal to replace one that had a tension ring? The first time I popped a crystal with a tension ring out of a watch I found that I had a suitable sized standard crystal and decided to try that.  It fit nicely and it was hard to see that anything was missing from the watch.  I understand that it probably reduced the water resistance of the watch but since it was an old dress watch it wasn't going for a swim anyway! I have since tried the same thing on another watch and found that the tension ring seemed to have an additional role of holding the dial in place.  With the standard crystal in there the dial and movement falls forward. This means it rattles in the case and falls forward and the hands fowl on the crystal (when the dial is down). Is there a trick I am missing here or does this watch require a special crystal?  I am reluctant to buy an expensive armoured crystal only to find I have the same problem.
    • So I wrapped the anvil it in bubble wrap and passed ot through the demag only. Still no go—the unit is simply too strong.  next experiment is to use a VARIAC to lower the voltage and see if that reduces the magnetic field.
    • In this case, the underside of the crystal is flat so I assume I don't have to worry about clearance to the hands. However, perhaps I'm missing something. If so, please let me know. I guess no one has the patience to get into the details of my first post so here's a simplified version of my question: The case diameter for the glass gasket is 36.9mm. However, Cousins doesn't have a glass gasket with that diameter. The closest are 36.8mm and 37.0mm. Would any of those two options work, and if so which one? I have no problem ordering both and testing them, but If someone already knows it is pointless, there's no reason to order. No, I haven't. Is there someone you can recommend? Preferably in Europe. Thanks!
    • No. It's incredibly volatile and evaporates in seconds; there is no way it would last as long as it took to just install the part cleaned in it, in the movement.
    • When I record how much I have spent on each watch I include the postage.  UK EBayers seem to be charging £5 minimum these days on postage.  Have made a couple of job lot buys recently - based on the average price this one could be 404 reboot project  Bad photo from eBay - 1 of 4 watches for a total of £21.19. A Medina with an MST 385 movement - Soaked in oil but looks like it will run again!
