Hi Len, I don't even own a jacot tool but I'd also like to know the answer. Hopefully someone here with experience in this matter will answer soon.
Cheers,
Bob
Hi there, Bob,
Yes, I am some-what surprised at the lack of response to my request for help.
I know that there is a machine that the Jacot tool can be used with, but there just has to be another (Cheaper) way of achieving the same result.
Never mind, I will use the 'trial and error' method.
Hopefully, the balance staff pinion will not meet the same demise as the one it has replaced!
If it does.........not a problem. I will simply pick myself up, dust myself off and say "oh dear!"
Len.
Hi there, Bob,
Len.
Sorry Len I missed you post. When removing / polishing a staff always remember you can take it away but to can not put it back. Therefore I use a burnisher with oil & slowly remove the material. You will see the oil changes colour which is the tiny amounts of metal that are being removed.
Here's a video showing a burnisher being used with a Jacot tool.
https://m.youtube.com/watch?v=x-qZklkLO2M
This process will remove a very small amount of metal, but the main reason for using it is to work harden the surface of the pivot and give a very hard mirror finish. If you just use an Arkansas stone to remove the the excess metal without burnishing, you will remove metal, but will not get the hardened surface that is required to prevent premature wear of the pivot when in use.
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
