Balance staff: is this a decent quality?
I‘m going to replace the balance staff of a Russian pocket watch (Molnia 3602). Because it is the first time I purchase a balance staff as a spare part I am not sure about the finishing quality to be expected. Here are some pictures from what I got (ebay, „NOS“). Is this a decent quality for such an item or is it chunk? Your educated comments are highly appreciated.
Edited by Kalanag
  • Kalanag changed the title to Balance staff: is this a decent quality?
The hub looks a bit rough and the pivot doesn't seem particularly polished but that might just be because the photographer seems to have taken the picture with a potato 🥔😉 . The rivet still looks like it has its shape though.
On 12/16/2023 at 5:02 PM, CYCLOPS said:
you should be able to use after clean-up in lathe as long as the hub fits the balance wheel.....
Meanwhile I found some time to investigate the dimensions of the new staff.
- The pivots fit the jewel holes
- The end shake is fine
- The wheel hub fits the wheel diameter
BUT
- The double roller ID is 0,2mm smaller than the staff‘s OD (0,4 vs. 0,6mm) 🤨
Not having a lathe, what would you folks do?
Edited by Kalanag
BUT
Jacot ?
5 hours ago, Kalanag said:
I should have mentioned that I don‘t have a Jacot tool.
Ronda catalog is showing the roller table diameter on staff as 56 maybe roller is too small . Could you measure on a reamer where you need to be with the size ? Stop short and finish with  a smoothing broach.  Reducing the staff would feel safer for me and normally easier to replace if things go wrong .
3 minutes ago, Kalanag said:
Well, there seems to be no other option than purchasing a reamer that I will never need again. I‘m not happy with this idea (yet).
Can a cutting broach do the job?
Well I’ll throw tuppence in the pot, the knowledgeable folks will hopefully chime in. A cutting broach is basically a reamer with a taper, I would think this would be what you would want for this but I may be wrong. A reamer is parallel and would be more for making a true hole. Saying that I think there are also tapered reamers kicking about for things like morse tapers.
Tom
I think that is what nev was meaning, reamer just being another term. I wouldn't be too happy either.
Do you have smoothing broaches that you can mark up the diameter on, so you have a gauge to work to. I do this when opening up a barrel hole so i know when to stop.
4 minutes ago, nevenbekriev said:
Yes, my english doesn't make difference between reamer and cutting broach. I try to improve it here...
Its ok nev those 2 terms are more or less interchangeable where ever you come from.  Reamers are often associated with their use in jewelling tools but some people also do call them broaches . Broaching and reaming mean the same, to open up a hole. Broaching a subject would be to open up a discussion usually a difficult one.
the roller or staff needs to have some taper to fit tight, you will use tapered reamers again and again in the future I'm sure, I don't know how you will hold the roller to do this maybe a pinvise.....be careful not to remove too much and hopefully the hole will not get out of round
Got this set of carb jet broaches (0,4 - 1,6mm) for just €9,- (shipping included). They worked well for the cutting. After finishing with a smoothing broach the result is fine 🙂
Edited by Kalanag
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
