There is a Portes VC-10  watch cleaner with a starting bid of $250.  Because it's local pickup only I think that I can get it for opening bid and have my brother pick it up and ship it to me in Milwaukee.  I'm useing a Watchmaster right now.  Is the VC-10 worth it?   Anyone have any experience with this machine?  Any advice?
It is missing the baskets but someone else has a set for $100.
To me the always look like something that belongs an operating room. I once worked in a shop that did the most watches of any shop I've ever worked at and that was the machine they used. So yes they do work but they're still a interesting design not that using vacuum to pull fluids up doesn't work Elm I has a machine that does that but then they throw in ultrasonic and the price is astronomical. Then I did look at the copyright date but I imagine the machine is actually quite old I don't know if you'll build a get spare parts baskets or anything else for them anywhere anymore
22 hours ago, markr said:
Any Idea if these worked good?
From a thread on nawcc:
Quote
I used to have one of these machines. Did a great job, but really only for a high volume shop since the fluid went bad quickly if you used it or not since it was all vented to the air when not in use. And it uses alot of fluid.
Even if you sealed the jars when not using, residue of fluid in the hoses and machine would become sticky, and then when you used the machine would mess up the good fluid.
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
    • Yes, the specific old tools do exist, but may be having one is not needed as they are not cheap, and also You will be able to do without it well enough. My advice will be to use regular depthing tool and adjust it for the exact distance between pallet fork and escape wheel bearings from the watch. Then remove the shellac from the pallet that now doesn't pass the ew teeth and move this pallet in. Then put the pallet fork and ew on the depthing tool and check how they lock. They should not lock when the pallet is in, but You will little by little move the pallet out and locking will appear. Then move just an idea out for reliable work and apply shellac, then check if things are still the same. You have to observe where the teeth fall on the pallets - it must be just a little below the edge between impulse and rest planes. Then You must check how everything behaves in the movement This Potence tool is so ingenious, but actually, the traditional way to do the things is much more simple. Arrange the parts not on the pillar plate, but on the cover plate. Only the central wheel will remain on the pillar plate, secured by the cannon pinion.
    • There is a tool that was made for setting up and adjusting escapements of full plate watches.  There were two styles, the picture below shows both of them.  The lower tool held a movement plate and the vertical pointed rods were adjusted to hold the unsupported pivots of the lever and escape wheel.  There was also a version of this tool that had 3 adjustable safety centres so that the balance pivot could be supported by the tool :  The other version I’m aware of is the Boynton’s Escapement Matching and Examining Tool came as a set of two or three clamps that gripped the watch plate and held the safety centres for the pivots : These do turn up on eBay from time to time.  For some escapement work, you can set up the parts in a regular depthing tool, with the centres set according to the distance between the corresponding pivot holes on the movement.  I hope this helps, Mark
