Seiko 7S26B rotor bearing adjustment?
I've done nickel plating in the past but using nickel solution and always plate with copper first as nickel bonds better to it and it removes any blemishes.
By watchweasol · Posted
As posted Andygsi they are usually bought in selections but can be made using a pin vice and some brass wire, available on eBay. -
Thanks for all the help. Starting to learn how all the parts are called in the meantime from the linked file. Taking me a while - old dogs, new tricks. Supposed to be good for keeping the brain active though! If there's deep scratches on the casing, is there any merit in taking it down to brass? I read nickel-plating brass is relatively easy and can be done with just a nickel anode and salt+vinegar solution - no need for crazy acids. Has anyone done it on a watch case with any success?
By LittleWatchShop · Posted
When I saw this, I knew I had seen these tools in my collection. Recently acquired estate for pennies. -
Thank you @AndyGSi for valuable insight. It helps a lot.
