Hi guys.
Received my Tissot that I'm using as a learning tool with the above movement in it.
Looks like some water damage. One of the movement holder screws is welded in. The movement works if shaken but it won't wind via the stem.
So Sunday is the day. Sit down and take my time :) tea and biccies.
James.
Sent from my HTC One using Tapatalk
Had a little time this evening.
1st part off. Looks ok not rusty and free.
1 problem is the stem release is stuck down so I can't line up the hands and can't safely discharge the main spring. Will have to wait till it stops manually. 09d3fafa31082161133f1affd19beaf0.jpg9fb7a40cca8a098de2e5836c79f47d8f.jpg
Looks like the movement needs some TLC . Can't you hold the mainspring with a little larger screwdriver on the barrel arbor screw?  And gently tighten it and release the click spring? And then slowly discharge  the mainspring .
Edited by rogart63
Yep didn't think of that :)
Lunch time update.
All parts removed.
Small amount of cleaning required.
aaadee452b46b1b1577168b46e584320.jpg2e99889282fb0e4e5cfbe557b94ed2f2.jpge4ec1fb0e7369dbdac228bffb3575df0.jpg9e2d7d2c0ad619a77876976f7abae7b1.jpg1cfdb29a69608716a0f6ad7d309c6a56.jpgcf6a4c311d66221202839976b8ae5a1b.jpgd2b402a9f0636d378595c46581130421.jpg3c1fa173d4b7c21f565acfdbb3246131.jpg5533cb16516584a4e5c7a6e66ffd9e65.jpgdc09e43d2a192521d0233eae44c3707a.jpg034de174d629b12a6298fbac2cba980f.jpg
Edited by Gingerr6
As you can see the movement holder screw is welded in, i have tried to lubricate it and even applied some heat but i just cant get it to budge.
The date wheel will be cleaned and re used but the dial is passed it , i noticed cousins have some Tissot dials, i also need a stem and crown, see dial below.
If someone knows what parts i need it would help me out massively.
so far not to bad for my 1st full strip and rebuild :)
James.
Edited by Gingerr6
Help on parts.
Dial
movement tab/holders and screws.
Stem and crown. complete and ready to fit if possible?? i now cousins do Tissot them but not sure how i find out what was fitted out of the factory?
Thank you!!.
James.
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
