Hi,
would appreciate your help please. I've been changing batteries at home for a couple of years using basic tool kit bought on line. So far had been successful. But things went wrong with my wife's watch.
After putting in the new battery and closing the case, it was immediately clear that the hour hand was misaligned. I've got no idea what I did to cause this, but with a little research, I wonder if I may have touched the copper coil.
The watch still keeps time, there are no other issues wrong with it apart from the hour hand.
Is there a way to reset the hand please?
The videos I've watched suggest removing the hands and putting them back in the right place, but it's not obvious how I'd access the face as the rear opening is smaller than the front.
Any help would be very much appreciated.
I've included photos.
Many thanks,
Simon
Hello and thank you.
The bezel and case seem to be all one thing. There's no discernable join anywhere. Am I missing something silly?
I've attached a couple more photos although not sure they help muchIMG_20230830_231149.thumb.jpg.404cc7e1bdd73a83d146926d6a4b5c43.jpg
Hi what Richard has said is correct , a case knife in the groove and twist the bezel will pop off and you will be able to re align the hands. First protect the dial while removing the hands the movement is miyota and quite cheap to replace should any mishaps arise.
it makes sense but I can't find the cut out anymore. And there's no perceptible join in the case. the case appears to be all one piece.
The cut out appears to be a flat spot imperfection which caught the light
I'm using my case knife to try and feel it but nothing so far and I'm probably starting to scratch the case
  • 5 weeks later...
thanks for all your advice. It took me a little while to find some time to have a go at removing the bezel. Unfortunately, I failed to find any kind of gap - under magnifying glass, work light, with a sharp marking knife - I just can't detect a gap.
My wife has seen a watch repair shop so that's the next step.
 How about removing the strap, thats where the cut out is located in some watch cases for aestetic reason, so to cover the cut out with the strap , as it usually gets scratched easy when its removed.
As Richard said, bezel is to  defnately  come off, since the dial is larger than the back plate.
Rgds
If you unknowingly loosen screws to the gear bridge, the arbour the hr hand is monunted could have turned.
Edited by Nucejoe
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
