Illinois Pocket Watch - issues & questions
Hello! I'm a newbie and couldn't work out how to introduce myself!! Thank you for your potential help. I have an old school Ice Watch and the Bezel is damaged. I'd like to replace it but I can't seem to find anywhere that mentions the size. To my measurement it looks like 39mm external diameter. Anyone any ideas? And where I could purchase such a thing? Thanks!IMG_6025.pdfIMG_6025.pdfIMG_6025.pdfIMG_6025.pdfIMG_6025.pdfIMG_6024.pdfIMG_6024.pdf
By transporter · Posted
OK so everyone has covered the veneer and case, I'll give you the springs, I make these myself and are very easy to do, measure the gauge of the wire and order some off ebay, then chuck up a rod of the same diameter or as close as you can get in the lathe, stick one end ( use super glue ) and slowly turn the lathe holding tension on the other end of the wire and keep the coils tight together. Once at the required length cut the wire slightly longer than is required and use acetone to free the stuck en, then using round nose pliers form each end. -
I have to ask this, if you took it apart to replace the suspension spring did you not sit and have a look at the working parts to see how they functioned together? -
Hi guys, was anyone at Upton hall this week for the BHI exams? If so, How did you get on?
