Yo👍
my names Scott
was just wondering if someone can help me with some watches that I need repairing
Rough estimate on how much it should/would cost to repair them
and also a rough estimate on the price of each watch once repaired
cheers🫡
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
We need good clear photos of the watches fronts, backs and sides please.
14 hours ago, Scottieg27 said:
Yo👍
my names Scott
cheers🫡
Depends on where you live: Gouge Eye, NV, or Outer Mongolia.  Also depends on what you want repaired.  Help us out and we will help you out.
On 7/10/2023 at 5:12 AM, Scottieg27 said:
Yo👍
my names Scott
cheers🫡
Hello it’s scott
the 1st and 2nd watch just need a new battery.
the 3rd watch needs battery and a link to re attach it together.
And the 4th watch also needs a new battery and a few links to re attach it all together and a piece connecting to the dial of the watch is bent.
14 minutes ago, LittleWatchShop said:
Numbers can vary all over the place.
Battery: $30
Mechanical service (the Ks): $300
My numbers are accurate to within +200%/-20%
Where are you??
How much for links for the other watches
and Im in the South East, Kent, Maidstone
With respect I think it would be better and more accurate for you (th OP) to get a quote from one or more local watch repairers. Any figures people give here would be purely speculative unless someone is promoting their own business which is not allowed on this forum.
Again, I mean no disrespect but this thread is not going to go anywhere so I’m closing it.
sorry.
  • Mark locked this topic
This topic is now closed to further replies.
    • Use probably the same key as you wound it with - on the end of the cannon pinion is a square that the minute hand is mounted to. You just need to turn the square, which will overcome the cannon pinion's friction and set the hands. That said, this could be the reason your wheel and pinion were separated and thread damaged. If the cannon pinion had been rusted or seized on and it was turned, it could have damaged the connection between the pinion and wheel. If it felt like your cannon pinion could turn on the center wheel arbor before and there is some grease under it, this should not be a problem.
    • I've gone the threadlocker route having tried the material insert approach without success. The watch runs but I'm chary about winding it more than a turn or so in case the 'repair' gives way; still, there's an element of satisfaction in getting it going at all as it's a single bridge/plate design which I could only assemble dial side up & then flip over in order to be able to insert the 3 securing screws. The reassembly took a number of attempts over many hours but at least I got considerable manipulation practice & the experience will come in useful in future. I'm now faced with my ignorance about how to manually set the the time as this key-wound Waltham pocket watch doesn't have the usual pull-out stem facility. All I can think of doing is to adjust the regulator arm until it catches up with the current time & then revert to the central position.....
    • So the crown should be a 0.9mm thread as you've ordered. How do you know the thread size is wrong if you've not removed the broken stem yet?
    • You'll need to be extra careful with the Citizen as Information along with Parts and Donors are pretty much none existing. You'll probably end up having to use a stem extender, that's hoping there's enough stem left in the movement.
    • Thank you! That's immensely helpful. I appreciate the trouble you've taken. The initial hiccup aside, I do hope to treat this watch with great care and respect. I've certainly learned one thing not to do, and also just the general need to start out very slowly and very carefully.
