Advice about winding a Smith Enfield clock that has wound down
I am trying to rationalize what is going on with this eta 955.112. It operates within the manufactures published specs for all tests, with the exception that when the stem is pulled out completely, the internal IC consumption jumps to 75ua. It should be < .5ua. 1st thought was faulty ground switch.... but hat did nothing. Swapping the electronic module fixed the problem- ruling out it being a grounding switch issue. Do i Just a bad movement? ot is there something else going on ? cold solder joint at ground pin? Has anybody seen this or want to take a stab at why
Definitely have a look around ebay for Arnex pocket watches. You'll find many that are still in their gift boxes, essentially new old stock Swiss movements for very low prices.
By watchweasol · Posted
Hello and welcome to the forum it’s an addictive hobby so be prepared.. attached a little help for you to read. TZIllustratedGlossary.pdf -
Hello and welcome to the forum, don’t be shy are you just starting on the horological journey or a seasoned pro -
