Punches for bushing in clocks
Michael1962
Hi everyone,
Labanda over here have two punch sets that are in their clock tools section. The first they call a closing punch set. I am not sure of what they are for, but if it is what I think, I do not think that I will spend money to get them. The other set are various sizes and end profiles, but all of them are too large for riveting some bushes in clocks that I have. The smallest ID of one of these punches is only 0.25mm smaller than the entire oil sink hole in the old Enfield clock that I got from Darwin. And that hole has already been bushed. The repair is as obvious as. No effort has been made to make the repair invisible.
I can only presume that these punches may be for setting gears on pinions if they are made from scratch or repaired.
So my question is, where do I get punches that will be small enough to rivet some of the bushes that I will need to be making to learn this task? Do I need to get myself a watch staking set to get small enough, or do I need to machine them myself from steel round on my lathe? That may be the easy option as I can then make them only as I need them to whatever size I need at the time. Bit of engraving with the Dremel and eventually make my own set. Custom making my own staking block would not be hard either. I also did a search online and came up with the same set that Labanda has. If anyone wants to have a look, the website is www.labanda.com.au and the SKU for them is T-292.
Here is the sizes that Labanda sent to me after measuring them.
The measurements are as follows
1- ID: 4.85mm OD: 9.5mm
2- ID: 4.6mm OD: 9.5mm
3- ID: 4.9mm OD: 9.5mm
4- ID: 4.5mm OD: 9.5mm
5- ID: 4.25mm OD: 9.5mm
6- ID: 4.2mm OD: 9.5mm
7- ID: 2.9mm OD: 9.5mm
8- ID: 2.8mm OD: 6.35mm
9- ID: 3.3mm OD: 6.35mm
10- ID: 2.6mm OD: 6.35mm
11- ID: 2.35mm OD: 6.35mm
12- ID: 1.9mm OD: 4.25mm
13- ID: 1.7mm OD: 4.15mm
14- ID: 1.5mm OD: 4.2mm
15- ID: 3.6mm OD: 7.6mm with centering tool
16- ID: 1.7mm OD: 5.05mm with centering tool
Hello my friend. You don't need any of them. If you have  a watch staking set that will do the trick, you can use the punches from that. you should never try to close a hole that is what was done way back in time, riveting a bush is also old practice, we don't do that anymore. You open up the hole by the means of reamers or  broaches.
Hi @oldhippy. So are you just relying on friction between the bush and the movement plate to hold the new bush in place?
That would mean getting the taper between the bush and the reamer or broach used on the hole to be exactly the same angle.
Edited by Michael1962
Yes that is correct it is not as difficult as it seams. the bush should be able to just fit in the hole and with a few taps of a small hammer it should fit tight in the hole, you might need a flat end punch to make sure it is flush with the plate, using a punch will make sure you do not bruise the plate.  Reamers  broaches   and bushes are all slightly tapered.
By making your own bush you can turn and make the oil sink so it is a good fit to the original oil sink by doing so you will find you do not need to make much of an alteration for it to match.
Edited by oldhippy
    • Welcome! To which part of India will my greetings go? Frank
    • I agree with @Waggy, no need to adjust. That looks very good to me. The factory specs for 7S26 are something like -35 to +45s/day, but they are usually better. The amplitude is good. When wearing, the most important positions are dial up, crown down and crown left. You need to regulate so that these positions average out to about zero. Crown down is showing +14, so you may have to set dial up to slightly minus s/day. The absolute values of +/-s/day don't really matter, as long as they aren't too far out. The only way to get good accuracy is to wear it for a couple of days, recording the errors, and gradually tweaking.
    • @Jon The link is no longer working and I wanted to see that demonstration again. Is there any chance you can make it available again? I'd appreciate it!
    • Or, if you have a staking set or jewelling too, just use one of the stumps. You can choose a fine tip to fit inside a jewel if necessary.
    • Good morning,   To be honest, I'm not sure I trust my own logic anymore 😅. But here's a picture of my own (failed!) attempt to install a new rotor axle. I punched way to hard and even split the metal of the rotor. My thinking was that, in my case, the axle sits "deeper" in the rotor and hence the rotor would be closer to the movement plates. Vice versa, I was thinking that a very light punch could cause the rotor to sit rather high. But not sure that makes sense because in both cases, the flat part of the axle and the rotor align equally.     Sorry, but is he saying that the outside of the caseback has been polished to such an extent that the inside of the caseback has deformed/sunk??? That sounds crazy to me because those casebacks are thick! Can you see any signs of that on the inside of the caseback? Have you tried screwing in the caseback a litte bit more or less so that the supposedly "sunk" part of the caseback would move from 9 o'clock to e.g. 6/7 or 11/12 o'clock?  If the caseback is truly deformed, maybe it could be punched/pressed back into shape (e.g. with glass/caseback closing press).      I agree with your choice. But yea, Rolex makes it VERY hard for independent watchmakers to do a perfect job because we can't get (original) parts easily.      Your pictures aren't too bad. But still impossible to see if the rotor isn't perfectly flat. You'd have to look at it with your loupe, from the side (like the pictures), and turn the rotor to see if the gaps (with the automatic bridge plates) increase/decrease.     Finally... how is the up/down play of the rotor? To test, take a toothpick/pegwood and press on the small triangular side of the rotor next to the axle (NOT the big side where the weight is. But the opposite side.). Does that lift up the weight-side of the rotor? There can be some play, but it should really be minimal. If there's too much play, a new spring clip is the first thing to do. After that, one could play around with the jewels. This is too much:
