Identical springs?
Bod
8 Day striking mantle clock, probably post war 1950's, but might be earlier. (1920-30)
In general would you expect the main going spring to be the same as the  strike spring?
i have the clock open at present, the main spring has had rust, the strike spring has had a new end hole punched, both springs are the same width, thickness, and length, (as best I can measure with string.) The main spring relaxes much more than the strike spring, at present I'm going to replace both.
Bod
I shan't go against oldhippy but in my experience so far I have not come across a strike with the same spring, mainly due to the extra work that train has to do it requires a stronger spring. These are my findings so far in the world of paid work in horology:)
Right hand spring is the main time spring.
Left hand is the strike spring.
Running a length of string around the coils, both are the same length.
L/h spring has had a new hole punched in the softened end.
Both are the same width and thickness, and as best I can judge the same strenght.
Thanks Bod.
I would replace both they both look tired / worn out. You need to measure the height from the inside up to to mark for the lid and the inside  diameter I expect both barrels to be the same but do both just in case.
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
