Click spring on a Smiths mantel clock
Rixy
I have taken apart a Smiths clock for cleaning and discovered a homemade click spring has been put in to replace a broken one on the strike side. The original had been riveted in place and the homemade one uses a different hole lower down and the bump of the old rivet as a stop for this makeshift one.  On the time side it looks like the riveted click spring has been successfully replaced with a screw-in one, using the old rivet hole. What are people's views on what I should do? Keep the makeshift spring? Try to remove the riveted remains of the original and screw a new spring in or have a go at riveting a new spring in place?20230507_220133.thumb.jpg.efadf1300363db27f212699cdf75d69d.jpg
Cousins do all types of click spring and i am sure they do that type, the only thing is you have postage and packaging on top if you live in the UK someone might have a spare one they can send you, i will have a look later today to see if i have one and get back to you if i do.
Replace it that is a horrid repair. You need to make sure the two holes are as near to the original to have a good fit you can always enlarge if needed. here are some that can help the first link is best. You cold look on ebay.
 https://www.cousinsuk.com/product/v-shape-by-size
https://www.cousinsuk.com/product/click-springs-assorted
It may well be a distorted cotter pin, or perhaps some twisted spring wire. When I saw it, I thought someone had taken a bit of coat hanger!
I have found a Smiths movement that I bought for parts a while back and didn't use. It fits the case perfectly and it all works, so I think the easiest thing to do is a 'transplant' and salvage what I can for spares.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
    • Yes I understand that. What I’m asking is, after the hands have been fitted, it’s been checked that the hands do not touch etc. then I need to remove the stem to fit the movement in the case. I have the push type, I need to turn it upside down and push the setting lever post and pull the stem out. But of course the dial and hands are in place and I have a glossy dial with lume dots and I do not want to cause any damage while it’s upside down pushing on the post of the setting lever.
    • You have answered your own question. You just push the setting lever nipple in or if its the screw in type unscrew it a little. You should always remove any hands and the dial before putting it in your movement holder.
